[ 3006.102.6 alpha Build(s) ] available build(s)
@Untried3868
Yeah, something got lost in the update because the update frequency is 1 second but the measurement is divided by 2 because I think it used to be 2 seconds.
That's correct. I only switched to every seconds a few days ago when I made it configurable within the code, and forgot to also replace that fixed "/2" with "/ (updateFrequency/1000)".
Weird. I'm not sure why I'm having such difficulty inserting/attaching an image.
Here's a direct link (remove spaces):
https:// i.imgur.com/Bx169MP. jpg
I don't think it's your problem. Looks like your image hosting is blocking the uk - direct link gives the same block page.
Let's try this again.
Edit: This is baffling. Screenshot taken from two different computers and they appear as vertical lines once attached to a post. One ~60kb and the other ~31kb in size, one linux and one windows based.
imgur have blocked access to users from the UK to avoid having to comply with the UK online safety act.
Stay safe out there!
What kind of browser and screenshot tool are you using? Do you have any screenshot blocking options enabled? I know on the Brave browser, there's an option to block Microsoft Recall from making screenshots. Just wondering if that might interfere. But the fact that it did it on linux too is also a bit baffling to me.
Those are the exact same images I get in Firefox with Canvas Blocking or “Resist Fingerprinting” enabled.
Bingo! We have a winner! Thank you.
  • Screenshot 2025-10-12 at 04-59-47 ASUS Wireless Router GT-AXE16000 - Traffic Monitor Real-time.png
The "2025-10-11" date is not in US format (that would be "month-day-year" or "MM-DD-YYYY"). The "YYYY-MM-DD" date format follows the ISO-8601 international standard used since at least the late 1990s, and it's common practice to use this ISO-8601 date in S/W meant for international markets.
One benefit is that the date string is easily sorted.
3006.102-6 alpha1 working well on my AX1100pro all clients connecting ,
Thanls
Not specific to this release but to last few versions of AsusMerlin (including this alpha release) and all of my remote clients connections to the Asus VPN server are totally broken as soon as the Wireguard VPN client on the router itself is turned on. As I need to have my VPN client on the router to be always-on, this renders the router useless for my usercase. I was hoping that this would get fixed with time but it is unfortunately still not working with this release.
Question, what is wireless3.3? This appears between WAN and LAN on the Traffic Monitor tab.
So does anyone have any idea what wireless3.3 is? I can account for wireless 2.4, two 5, and 6 GHz, but no clue about 3.3. Could this be related to the guest network? It's the only thing I can think of.
I am sure they will get the same problem in all of EU -EU and UK normally agree on that matter
Upgraded my BE88U and have a log full of this entry
Anything to worry about ?
Unrelated to this firmware release, as the only changes are currently at the webui level, plus an OpenSSL security fix, and an IPv6 PD fix (that already existed in 3004).
When you hover the mouse over these buttons, shouldn't a hand be displayed?
Perhaps the size of the buttons' contact area should be increased a bit.
I didn't see it but is internet speed test fixed in this version? On my AXE-16000 it's been broke for a few versions and just shows what shows in this picture below.
Asus's page. I avoid touching these especially for things as trivial as visual tweaks, as it would just make them more difficult to maintain for very little reason.
