[ 3006.102.6 alpha Build(s) ] available build(s)
I didn't see it but is internet speed test fixed in this version? On my AXE-16000 it's been broke for a few versions and just shows what shows in this picture below.
I don't think it's broken, it's intentional. Asus knows they can't run a 10 Gbps speedtest using the router's modest CPU, so they don't allow speedtests when the linkrate is over 5Gbps.
Well that makes me a bit of a sad panda lol.. Glad I didn't do the 5gb fiber upgrade for 104 a month from AT&T I guess.. Thanks for telling me this and code does make sense.
Also, the server in the other end can probably NOT deliver 10 GBit/s (the internet is not upgraded just because you are). You would be very disappointed if you only got 1 GBit/s in the speedtest, although that could very well happen.
I'll say I pretty consistently hit around 2.3-2.4 gigabits on my 2gb fiber connection so that is nice at least but that is bypassing the gateway and such. I honestly don't have access to 10gb and doubt I'd ever want to pay that premium unless it was somehow as cheap as my 2gb or a few $ a away like 5gb could be... It just has a 10gb link because of how I did my bypass with a vlan and such from my 10gb switch. So it has 10gb on the the WAN and then 10gb on the LAN into my 10gbit switch. I only have 2gb that is over provisioned though.
I believe that the unbound page is broken from this update. Everything else seems fine, though that page stopped rendering following the install. I fully removed, purging all data, reinstalled, and rebooted and see the same blank behavior with the sidebar also not showing.
Alpha1 has been running for several days without any hitches on my GT-AX6000 main/AP combo. Site-to-site VPN, one GN, some manual DHCP address assignments. All good.
Installed Alpha1 on GT-BE98 Pro, plus AiMesh GT-BE98 Pro node (always remove node, search and reconnect after updates). The Network Map listed like five times more clients then reality after the update.
Normally run ASUS Stock firmware on AiMesh nodes, just some extra playing tonight to see what works as Merlin code on AIMesh nodes, have had some quirks over the years.
GT-BE98 Pro worked fine. What didn't work on Alpha1 was the RT-BE96U in AiMesh node, in that "No Devices would connect". After trying twice from Stock to Alpha, back to Stock to Alpha, ended up back on Stock Firmware level "FW_RT_BE96U_300610238984" with some devices connected again.
Client count back to reality after about 15mins. Assume some table building going on, or similar...
This morning...some invisible Clients back..
Yeah. Me (and some other ppl) got this since 3006.102.5 (see my post history, like this one).
As I understand it something has to be fixed by Asus (?).
It will start to do it again after some time, count up and then drop down to normal values. Then it starts counting up again.
I have 55 days stable uptime right now so it doesn't impact anything i can notice but it makes the client count useless ofc.
No support on alpha builds !
3006.102.6 (xx-xx-xxxx)
- NEW: Redesigned Traffic Monitor pages.
- Uses Chart.js for Realtime and Last24 pages
- Removes legacy Tomato code
- Last 24 can be zoomed in and panned (mouse wheel
and pinch-to-zoom gestures are both supported)
- Realtime and Last 24 now show as bits/s instead
of bytes/s
- Settings moved from the tab to the dropdown menu
- Number formatting is automatically localized
by the webui language
- UPDATED: OpenVPN to 2.6.15.
- FIXED: IPv6 requests for prefix lengths other than 64 for
routers with Multiwan support.
- FIXED: CVE-2025-9230 in OpenSSL (backport by RSDNTWK).
- FIXED: Client name would be missing on the Wireless Log
page if the MAC was missing in the DHCP lease list
(for static clients for example)
Another alpha is online...
Oh, the suspense is killing me; can’t see anything in the change log compared to the first alpha … 😆
Dirty upgrade from 102.6_alpha1-g2480b89a4a to 102.6_alpha1-gc3ecf6dda6. No issues to report.
Changes are almost always on Github, except when working on a private branch like the current RT-BE58_Go development.
I tested alpha 2 on my RT-BE92U but ran into problems with WiFi constantly turning off and rebooting intermittently. After a few attempts, I was able to go back to alpha 1 instead. I just want to mention this because not even the RJ45 cable would work with the latest version.
All's good on new Alpha (g5507234591). Network Map, Client numbers still crazy large values. As per earlier appender, on these Alpha's, everything does seem a little quicker & smoother on GUI's then the earlier 102-5 levels.
Everything running fine, including WiFi7 and MLO with 2.4 & 5 GHz bands on a mesh setup with the BE88U, BE86U & BE82U mesh nodes (both nodes running stock). Only issue that might be related is the Unbound user page not loading properly, cutting off the left side and not showing data unless you toggle lines or fill.
Unbound 3.25 on 102-6 Alpha. Appears everything fine on SSH operation. The GUI locks up the display, no data. Thought this GUI worked on 102-5 level. Over to.. @Martineau
