[ 3006.102.6 alpha Build(s) ] available build(s)
Unbound 3.25 on 102-6 Alpha. Appears everything fine on SSH operation. The GUI locks up the display, no data. Thought this GUI worked on 102-5 level. Over to.. @Martineau
Remember, in this struggling add-on community, the Unbound UI belongs to another guy here:
It seems Martinski is the guy everyone is depending on for updates. Other people need to start studying JavaScript and shell coding before the whole third-party add-on scene implodes.
After three days I saw this little hiccup:
Oct 19 23:24:20 kernel: enet_update_bond_config:L1785 port_0:0 already a member of bond group = 0
Oct 19 23:24:20 kernel: enet_update_bond_config:L1785 port_0:1 already a member of bond group = 0
Oct 19 23:24:21 kernel: enet_update_bond_config:L1785 port_0:0 already a member of bond group = 0
Oct 19 23:24:21 kernel: enet_update_bond_config:L1785 port_0:1 already a member of bond group = 0
Oct 19 23:24:22 kernel: bond0: Error: Device is in use and cannot be enslaved
Oct 19 23:24:22 kernel: bond0: option slaves: unable to set because the bond device is up
Oct 19 23:24:22 kernel: enet_update_bond_config:L1785 port_0:0 already a member of bond group = 0
Oct 19 23:24:22 kernel: enet_update_bond_config:L1785 port_0:1 already a member of bond group = 0
Bonding lan1 and lan2 is enabled.
Any comments/ideas?
Thanks for your guidance, tips & just how-too, pointers etc. JavaScript & Shell Coding...sadly...missed that calling.
Updated GT-BE98 Pro v3006_102.6_alpha2-g3793188ddc is available as well which moves to newer GPL 39099. I will update as soon as I have a break in Internet usage this morning.
Looking forward when the firmware for the RT-BE86U gets updated to the newer GPL.
Dirty upgraded from 3006.102.5 to 3006.102.6 alpha2. At fist glance the UI feels snappier, and I didn't update to the previous alpha, so it's my first time seeing the fantastic traffic monitor. Devices seem to distribute more evenly across the nodes. So far so good!
Updated my GT-BE98 Pro to alpha2 with no issues. I also flashed newly acquired RT-BE58 Go (delivered today) to its alpha2 -- continue to explore (and play with) its features as I have time.
Ooooohhhh… my crystal ball is seeing a separate thread with a review coming up :-)
How stable is this especially for Wi-Fi 7? Anyone running RT-BE86U with this FW?
Since this thread is about testing alpha software, feel free to join in.
I'm running this on a BE88U with WiFi7 and MLO enabled. Two nodes, BE86U and BE82U running stock. Multiple VLANs and separate SSIDs for different devices, etc. No major issues to report.
Alpha 2 is only available for a subset of supported devices? (So far?)
(I don’t see it for GT-AX6000 for example)
WiFi7 devices that have newer GPLs available...
What are you talking about, I have the alpha 2 and had 1 on my device; did you even open the link for alpha downloads...??
Unless you mean literally the alpa 2, which is infact alpha nr. 3, is as above per visortgw...
Yes, of course I opened the link.
For GT-AX6000 there are two alpha 1 builds (from commits g2480b89a4a and gc3ecf6dda6), but no alpha 2 builds (I’m referring to the numbers in the filenames, as assigned by RMerlin; not just counting the number of published builds).
The explanation from visortgw makes sense.
