4tb external won't stay mounted - rt-act68u, ext4
  • Thread starter Thread starter sorinut
  • Start date Start date
S
sorinut
Guest
I've had an external 4tb (single partition with NTFS and ext4) on my rt-ac68u with NTFS for a year or so, recently I changed it over to ext4 to supposedly increase the transfer speed. It is faster, while it is mounted, but will only stay mounted for about an hour.
I've dug through the logs and found this:
15:37:49 kernel: usb 1-1: USB disconnect, address 2
Sep 6 15:37:51 kernel: JBD2: I/O error detected when updating journal superblock for sdb-8.
Sep 6 15:37:51 hotplug[25613]: USB partition unmounted from /tmp/mnt/TOURO
No other logs relating to the drive. I have no idea what to do except change it back to NTFS. Any ideas?
A guess, but on Tools>Other Settings, set the Regularly flush caches tweak to 'No'
Only other suggestion is to disable any power savings features that are local to the drive (the drive may be spinning down and taking too long to spin back up).
That doesn't explain why it didn't have any problems for well over a year while it was formatted NTFS. Whenever I would browse the share, I could hear it wake/spin up and then I could browse it. It never unmounted.
NTFS uses a completely different 3rd party driver vs the built in linux EXT4 support. You would think that NTFS would be more susceptible to problems though. But stranger things have happened.
After updating to 380.68_4, it seems to be fixed. Hasn't disconnected since Sunday.
