Thanks Tim for this review.
1) The addition of the access points clouds the dual band USB adapter data. Given a 2 to 3 upload to download usage ratio and a 1 to 1 adapter lifetime 2.4 to 5ghz usage ratio using and average of the best and worst location scores, here is what I came up with for the USB adapters:
D-Link DWA-160 (B1) USB 23.61
NETGEAR WNDA3100 (v2) USB 22.78
Linksys / Cisco WUSB600N v2 USB 19.17
Applying the same logic, the PCI express mini card (Intel 5300) came up with a far better score, especially in the 5ghz band:
Intel WiFi Link 5300 PCIE mini card 29.79
Perhaps the vendors just run out of real estate on these USB adapters?
2) The lowest common denominator approach of this article servers those who use hotspots quite well, but I am not certain about home and corporate router purchasers. They will tend to look for the best overall performance for their environment. Your wndr3700 review article hinted at a far higher throughput for the wnda3100v2 adapter with the wndr3700. Even the Intel 5300 performance varies widely (using same method as above):
This article's Intel WiFi Link 5300 PCIe mini card 29.79
Original wndr3700 test - intel 5300 w/20mhz 42.39
Original wndr3700 test - intel 5300 w/40mhz 50.83
I would have expected the first 2 to be about the same. Perhaps this is due to different firmware on the wndr3700?
Outside of the Intel 5300 PCIe option, my gut feel is they would be best served by a matching adapter from the vendor for the router with both tuned for best performance.
3) I do wish that these dual adapters would factor in likely competition into their selection. 2.4 generally always get selected over 5.0 with the wnda3100 v2 even though the 2.4 is congested and the 5.0 is clear.
Thanks once again for your article. These comments would not have been possible without your highly consistent data.
