Ability to view negotiated NIC speeds on LAN ports of AIMesh Nodes?
Colin1234
I can see negotiated NIC speeds on the main router via Tools->SysInfo but I do not see a way to view NIC speeds on the LAN ports of the AIMesh Nodes, specifically with the AC66U B1 or the AC86U. Is there a way to do this?
Here, AiMesh\<node>\Network\Port Information displays the Ethernet ports... hover the mouse over them to see their link speed.
OE
Weird, I don't see anything under "Network" that lists "Port Information" other than the Uplink (WAN) port.
EDIT: The "Port Information" section is visible for the Main Router if I select that under AIMesh. If I select the specific node as in the photo below, I don't see that info.
My guess is that your node firmware does not support this... looks like this for my AX86U node... LAN1 is wired at 100Mbps:
OE
