AC5300 and GT-ax11000 Firmware compatibility
José Manuel
Hola Tengo un router AC5300 y un GT-AX11000, el primero con el firmware de merlin wrt,
mi pregunta es puedo instalar la copia de seguridad el primero en el segundo?
Hello I have an AC5300 router and a GT-AX11000, the first with the merlin wrt firmware,
my question is can i install the backup the first in the second?
My guess would be no.
Mi conjetura sería no.
The GT-AX11000 has a beta version with SHA256 = a0d9e8d2a67cd3a77d94b287c521c5118d536d6c78ef8776d778fb3ca9f02e7d GT-AX11000_386.2_beta2_cferom_ubi.w
The AC5300 has a beta version with SHA256 = fdf58fcf15284b2c6b4a8c2112af39a5acfe038f722533d7cda01c8dcde86827 RT-AC5300_386.2_beta2.trx
The SHA256 checksum's do not match, which likely indicates what could be a substantial difference in the ongoing testing firmwares.
The AC5300 with stable version 396.1_2 SHA256 doesn't have a stable version 396.1_2 SHA256 of GT-AX11000.
