AC86U - Lose WiFi on all devices - Disassoc Event Spam - Upgraded from 384.17 to 384.19
halsafar
This started happening as soon as I upgrade from 384.17 to 384.19.
About 10 minutes after a reboot the log is filling with this message for every WiFi device every ~30s or so:
Dec 13 10:38:28 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth5: Disassoc [redacted], status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
After about 30 minutes of this log spam all my Android devices and Google home devices lose WiFi and I have to reboot the router.
I can find many posts about similar log spam, none of the offered solutions resolved the issue. I've tried the common suggestion of setting a single static value for Control Bandwidth and Control Channel on both 2.4g and 5g. This did not change anything about the problem.
I'm open to suggestions. Any steps I can take to help narrow down the cause? Should I just revert back to 384.17 (is that possible?)
Update: Downgrading to 384.17 seems to solve the WiFi issue but also leaves me unable to login due to 384.19 encrypting the passwords or something.
wlceventd is logged when a wireless client connects/disconnects.
Could be the clients do not like the channel you are using.
Could try going into wifi professional setting and disable airtime fairness.
I also disable roaming assistant on the AC86.
As long as you will have to do a factory reset, why not give 386.1 beta 1 a try.
When upgrading from the pre-384.19_0 firmware, you should've saved a backup of your JFFS partition before you flashed to the new 384.19_0.
After flashing, ideally, you should do a full reset including selecting the box to 'Initialize all settings...' before hitting the 'Restore' button. And, format the JFFS partition on the next boot too, and then proceed to reboot 3 times in the next 15 minutes (and waiting 5 to 10 minutes between each reboot).
For many though, simply formatting the JFFS partition (it shrunk 1MB for Asus security settings), rebooting 3 times, and then restoring the backup you made while still on the previous version of the firmware would be all that was required.
For yourself at this point, I suggest you need to move forward. Forget running the old firmware today.
Flash either the 384.19_0 release final or the 386.1 Beta 1 (or wait a few days for Beta 2 to be released for your firmware). Then proceed to do a full reset, format the JFFS partition, and do a minimal and manual configuration of the router to secure it and connect to your ISP.
The link in my signature may be helpful to get your router back to a good/known state and to have it use the defaults it's expecting (specifically, see the M&M Config and also the Nuclear Reset guides too).
