okay, thank you. just want to double check I have understood you correctly?Ethernet backhaul is essential in AP mode as wifi isn't used to communicate between AP and router/switch.
Much obliged Ripshop. Thank you.No need to activate that setting as you're not running aimesh.
Sorry just saw your post. Thanks for confirming.AiMesh and AP mode are different.
Don't mix options with one mode when using the other.
Have you tried disabling 802.11ax/wifi6 on the 2.4 Ghz band. Did this for mine and my esp based devices stay connected for >24 hours at a time now.but im still struggling to keep these tuya bulbs and switches online after something as simple as a router reboot lol absolute nightmare.....
im not giving up there must be a way!
Yeah had that one in my bookmarks, thanks.Do you have this one too?
Troubleshooting 101 Asus/RMerlin Routers 2020
Top 10 Simple Asus/RMerlin firmware powered Router Troubleshooting steps to try first: NOTE: Although this is for Asus/RMerlin-firmware powered routers, the steps below may be relevant to all routers, to get to a quick fix for common symptoms. Check that the router’s System Time is accurate on...www.snbforums.com
I'm not seeing that setting anywhere?Have you tried disabling 802.11ax/wifi6 on the 2.4 Ghz band. Did this for mine and my esp based devices stay connected for >24 hours at a time now.
802.11ax / WiFi 6 mode is not showing in my 2.4Ghz settings.Have you tried disabling 802.11ax/wifi6 on the 2.4 Ghz band. Did this for mine and my esp based devices stay connected for >24 hours at a time now.
D'oh!! Definitely early to bed for me tonightI'm not seeing that setting anywhere?
I managed to get a stable network
The main router and 5 access points are all AC86U.You never mentioned what model is your main router and what model is(are) your access point(s).
Your RT-AC86U (whatever it does on your network) is the most unreliable Asus router from NHD series.
Welcome To SNBForums
