I downloaded it from Merlin's site.Did you download from Merlin’s site, or compile the firmware yourself? Adaptive QoS cannot be compiled anymore by users in 386.
Unfortunately, the recommended steps did not work.Does switching to English and rebooting the router help?
Did you use a saved backup file by any chance?
The following suggestions may help.
Beta - Asuswrt-Merlin 386.1 Beta is now available
I recently factory reset my AX88U and currently on Beta 2. After manually setting up everything up again (painfully) my router ALWAYS "crashes" if I make changes now. well I just loses internet and I have to end up rebooting it even though some of the changes made by default doesn't require a...www.snbforums.com
New M&M 2020
I tried enabling it through SSH with commands nvram set qos_enable=1 and nvram set qos_type=1, the menu bar at the top showed the gear icon saying it was "enabled" but the classification page showed blank graphs. I tried installing FlexQOS which did not help.Unfortunately, the recommended steps did not work.
It's a DSL-AC68U whose DSL modem died so I just flashed Merlin to use it with a bridged ISP modem.Is it a real 68U and not something that was "made" to be one?
that may explain it. i'd recommend trying the DSL firmware anyway: https://www.snbforums.com/threads/d...alphas-for-dsl-ac68u-are-now-available.68295/It's a DSL-AC68U whose DSL modem died so I just flashed Merlin to use it with a bridged ISP modem.
That's why the support tech in me always asks for more informationFull disclosure of all pertinent information always brings about a better and faster answer to a real solution.![]()
Welcome To SNBForums
