After reboot, Asus GUI lost addons and nvpnmgr
Chuckles67
Merlin 384.18
Asus RT-AC66U B1
I rebooted my router several times today whilst experimenting with Dual WAN (long story - not important here).
Now in the router GUI, I can not see
- add-ons menu (with spdMerlin and conmon tabs)
- nvpnmgr tab in VPN
- uiDivStats tab in LAN.
However I can still see flexqos tab in AdaptiveQoS.
On the command line with amtm, all apps mentioned above are working fine. Any known work-around to restore the missing GUI tabs?
Merlin 384.18
Asus RT-AC66U B1
Can you check syslog for any messages from those scripts as to why they didn't start? Also check for updates in nvpnmgr, i pushed a small fix yesterday
All script tabs are restored after a reboot this morning.
=> all looks good now.
Thanks Jack - nvpnmgr version is at 1.0.0, I ran a check in the gui tab, also command line update nvpnmgr > "u" check.
The first time stamp I see in the router-gui syslog was after the reboots yesterday that (I think) triggered this issue. All nvpnmgr entries look normal, as do spdMerlin and uiDivStats. I think I did not get to the syslog in time to see what happened yesterday.
