Almost there.. need a little help with custom DDNS script
MKANET
I'm using the provided DigitalOcean script here:
Only changing:
ACCESS_TOKEN="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
DOMAIN="website.com"
RECORD_ID="xxxxxxxxx"
I've set the script as an executable; placing it in the correct directory; and, allowing Merlin to use jffs scripts.
I am able to use the CURL command to do the same thing:
curl -fs -X GET -H "Content-Type: application/json" -H "Authorization: Bearer xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" -d "\"data\":\"xxx.xxx.xxx.xxx\""  "https://api.digitalocean.com/v2/domains/website.com/records/xxxxxxxxx"
However, on the merlin DDNS interface, I get the DDNS status error: Request error! Please try again.
In the Merlin System Log, it keeps showing:
Nov 22 15:25:34 watchdog: start ddns.
Nov 22 15:25:34 rc_service: watchdog 352:notify_rc start_ddns
Nov 22 15:25:34 start_ddns: update CUSTOM , wan_unit 0
Nov 22 15:25:34 custom_script: Running /jffs/scripts/ddns-start (args: 76.103.91.162)
Nov 22 15:26:04 watchdog: start ddns.
Nov 22 15:26:04 rc_service: watchdog 352:notify_rc start_ddns
Nov 22 15:26:04 start_ddns: update CUSTOM , wan_unit 0
Nov 22 15:26:04 custom_script: Running /jffs/scripts/ddns-start (args: 76.103.91.162)
What am I missing or doing wrong? Thanks in advance for your help!
Update. I got it working. I had done everything perfectly before. Except, I had created the ddns-start using a tool like, "WinSCP". I had to follow the instructions in the link below to create the file using CAT... then, pasting the contents in the file.. and finally adding execute permissions:
  • Like
Reactions: gkh
