ddns watchdog restarting every 30 seconds
jorhett
Watchdog is starting DDNS every 30 seconds.
Dec  6 04:38:09 watchdog: start ddns.
Dec  6 04:38:09 ddns: update CUSTOM , wan_unit 0
Dec  6 04:38:09 ddns: Clear ddns cache.
Dec  6 04:38:09 custom_script: Running /jffs/scripts/ddns-start (args: 200.82.19.61)
Dec  6 04:38:10 ddns: Completed custom ddns update
Dec  6 04:38:39 watchdog: start ddns.
Dec  6 04:38:39 ddns: update CUSTOM , wan_unit 0
Dec  6 04:38:39 ddns: Clear ddns cache.
Dec  6 04:38:39 custom_script: Running /jffs/scripts/ddns-start (args: 200.82.19.61)
Dec  6 04:38:40 ddns: Completed custom ddns update
Dec  6 04:39:09 watchdog: start ddns.
Dec  6 04:39:09 ddns: update CUSTOM , wan_unit 0
Dec  6 04:39:09 ddns: Clear ddns cache.
Dec  6 04:39:09 custom_script: Running /jffs/scripts/ddns-start (args: 200.82.19.61)
Dec  6 04:39:10 ddns: Completed custom ddns update
(that's not my real IP)
I've confirmed my ddns-start script is working, and also confirmed that it's setting the completed variable:
router:/jffs/scripts# nvram get ddns_updated
1
Looking at other threads, the only thing I've found is that ddns_ipaddr is not set
router:/jffs/scripts# nvram show 2>/dev/null | grep -E "ddns_ipaddr=|wan0_ipaddr=|wan0_realip_ip="
wan0_ipaddr=200.82.19.61
routwan0_realip_ip=200.82.19.61
Model RT-AX86U running 3004.388.5
What scripts do you have installed? I don't find /jffs/scripts/ddns-start on my router. Is this only since updating to 388.5?
It's possible a script needs updating, or is no longer compatible, or you need a factory reset and manual setup.
Edit: RT-AC86U running 388.5?
1
Model RT-AC86U running 3004.388.5
I had noticed a similar behavior, but after an update to the latest firmware on my AX88U Pro it has stopped. Since you are running that version that needs some more digging I'm afraid.
This is the script you have to create if you use the "custom" choice for DDNS. It's not a matter of what's inside the script, it's that it is being invoked every 30 seconds even though it completes successfully.
So I tried turning off the "IPv6 Update" option showing in the screenshot above, and the 30-second refresh disappeared. Very odd behavior given that every time it called the script it only offered the IPv4 address :confused:
I've noticed that I run into this update cycle if my WAN goes down as well. Once my WAN connection is stable again and I have a visible WAN address on the Network Map page, I get the same 30 second refresh loop. Hitting "apply" on the DDNS page forces a restart of the DDNS service and corrects it.
I have IPv6 Update on as well, using 3004.388.5 on an AX-86U Pro. The only script I have installed is scmerlin, along with a 2 GB swap file. I didn't use DDNS on original firmware, so I'm not sure if this is exclusive to Merlin or not.
