So we bought a new home, but after moving in noticed a bit of an issue. Because of the design/layout of the home running CAT5 is either impossible or expensive so I'm left with having to do MoCA (there's Coax in every room). By default, MoCA speeds (MoCA 1.1) aren't really all that great for the application I"m using it for (1080P content streaming from my home theater) however I got a lead on some MoCA 2.0 devices that I'm purchasing... Now I know that whatever the lowest speed or MoCA version is on a particular channel then all devices on that same channel will default to it and I would need to change the channels on my Actionet router and STB's so that it's not using the same channel as my MoCA 2.0 bridge however I'm wondering if there needs to also be a direct line from the ONT as well or can I split it? So for example my router and all networking stuff is in my office however the devices I need to get networked in are located in my home theater. So I was going to use a Coax splitter from the Coax drop in my office and run a line to the MoCA 2.0 bridge in the office and the other line to the MoCA 1.1 bridge (actionet provided by Verizon) in the office. The 2.0 bridge will service my HTPC in the theater area and the 1.1 bridge will service my STB's around the house. I'm going to configure the 1.1 devices on a different channel than the 2.0 devices. Now in my head this should work however are there any aspects of this I'm missing that might prevent this from working? Thanks in advanced for the guidance!
