Packets is lost when trying to ARP spoof my Asus RT-AC86U (asuswrt-merlin Firmware Version:384.14_2). I can see the ARP table is updated. I doing this on my own home network so have full access to router and the target mac.
I call: arpspoof -i wlan0 -t 192.168.1.1 -r 192.168.1.101
I found -r in the manual (Since most tutorial suggestion to run this separate):
flag -r Poison both hosts (host and target) to capture traffic in both directions. (only valid in conjuntion with -t)
I can see the ARP tables is updated in both mac and router with the attackers MAC address.
Here is a map of the network(I have removed the 6 last digits):
I run the command: dig @ns-604.awsdns-11.net forums.hak5.org
Here is DNS request 1 in wireshark running on kali (src: mac, dst: kali ) Note that this first line is highlighted.
Here is DNS request 2 in wireshark running on kali (src: kali, dst: router ). Note that this second line is highlighted.
The last message that is sent to 0C:9D:92 is never seen when I do tcpdump on the router.
I have to little knowledge about tcpdump but guess it monitors packets that goes across the interface. So if the DNS request was discarded directly could explain why I didn't see it when running tcpdump -i eth5 port 53 on router. However can't explain why it should been discarded since it works when I do the request when I run dig directly on kali-pc.
Any suggestion what could cause this? I will see if I can find any logs where I can see discarded messages or if I can find any other logs to see where the message disappear.
Just as info eth5 (wifi 2.4) and eth6 (5Ghz) and eth1-4 is the ports on the router. I didn't know about this before I thought it was only one interface br0, but br0 is the interface for the public wifi.
I think it might be something with the iptables. However I don't understand them so include them here incase someone else can see something wrong with them:
admin@RT-AC86U-D368:/tmp/home/root# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
INPUT_PING icmp -- anywhere anywhere icmp echo-request
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
DROP all -- anywhere anywhere state INVALID
PTCSRVWAN all -- anywhere anywhere
PTCSRVLAN all -- anywhere anywhere
ACCEPT all -- anywhere anywhere state NEW
OVPN all -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
INPUT_ICMP icmp -- anywhere anywhere
Chain FORWARD (policy DROP)
other2wan all -- anywhere anywhere
NSFW all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain ACCESS_RESTRICTION (0 references)
Chain DNSFILTER_DOT (0 references)
Chain FUPNP (0 references)
Chain INPUT_ICMP (1 references)
RETURN icmp -- anywhere anywhere icmp echo-request
RETURN icmp -- anywhere anywhere icmp timestamp-request
ACCEPT icmp -- anywhere anywhere
Chain INPUT_PING (1 references)
DROP icmp -- anywhere anywhere
Chain NSFW (1 references)
Chain OVPN (2 references)
Chain PControls (0 references)
Chain PTCSRVLAN (1 references)
Chain PTCSRVWAN (1 references)
Chain SECURITY (0 references)
RETURN tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
DROP tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/SYN
RETURN tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
DROP tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/RST
RETURN icmp -- anywhere anywhere icmp echo-request limit: avg 1/sec burst 5
DROP icmp -- anywhere anywhere icmp echo-request
RETURN all -- anywhere anywhere
Chain default_block (0 references)
Chain logaccept (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
Chain other2wan (1 references)
