AsusNovice
I have managed to setup Wireguard on 2 x RT-AC86U on USB sticks. It works "conventionally" as a Client > Server using the standard configuration files e.g. wg0.conf for the client and wg1.conf for the server. The RT-AC86Us are continents apart and each end on a "normal" ADSL connection i.e. IPv4 addresses and DDNS work.
I understand that the theory is Wireguard is not directional, but "peer-to-peer". In practice, as a VPN I rationalise what I am after is a Wireguard client and server (the client initiates the connection to the server), and once the connection established the VPN I want is the other way direction i.e. I am at the Wireguard Server end, but want my internet traffic routed via the Wireguard Client end. The complexity is needed because the desired ISP at the VPN Server end uses CGNat i.e. DDNS does not work / there is no IPv4 address (nor IPv6 yet).
As per upper half of attached PDF, I have got this working between 2 Windows PCs on: the right PC connects outbound from the CGNat end to the left PC behind normal ADSL. Once connection is made, internet requests from the left PC are routed via the right PC / ISP. Trial and error showed one or more IP addresses must not go via the VPN, hence I blocked off 162.0.0.0/8.
I now want to replicate it using the 2 x RT-AC86U routers, at the same locations. However, the Wireguard setup on Merlin / USB appears to assume a more dedicated client / server relationship e.g. in S50wireguard, and whether it uses wg0.conf or wg1.conf. I have got the Asus's working together over ADSL connections in the conventional manner, but wish to replicate the Windows setup above with CGNat.
I have, via luck
trial and error got it working to handshake / send KeepAlive packets i.e. the wg commands at each end show regular traffic each way... however, the internet traffic from e.g. wireless clients of the (left) RT-AC86U is not routed. I suspect it is due not understanding all the routing stuff in wg-server, or knowing enough to use wg-up / wg0.conf on the (left) VPN client end.
Any assistance would be very welcome
If there are different flavours of Wireguard on the Asus RT-AC86UI used this youtube link
I have, via luck
