ASUS AC86U - Connect via VPN Server with VPN Client Strict Selective Routing
alvinezz
Hi all,
I am new to all of this and need some guidance please.
I can connect to my home network from external network via VPN Server (opvn) I set up in the router.
The router also have VPN Client (with PIA) set up with selective routing.
However, I can only get the VPN Server connection working if I do not select "Policy Rules (Strict)" in the selective routing of the VPN client.
"Policy Rules" works though.
My VPN Server subnet is the default, i.e. 10.8.0.0 / 255.255.255.0
I have tried to add the following to the selective route of the VPN client.
Source: 10.8.0.0/24
Destination: 0.0.0.0
Interface: LAN (tried WAN also did not work)
The other routes are for my local LAN IPs, e.g.
Source: 192.168.1.0/24
Interface: LAN
Is this something wrong with these routing configs hence VPN Server connection cannot access the devices in the LAN?
Anything else I should check?
