ASUS RT-AC68U Router WAN disconnection.
Novice
Hello,
I'm new to this forum and to ASUS router. I recently bought a new ASUS RT-AC68U router for my home but I'm facing frequent WAN disconnection issues which I'm unable to understand.
My ISP uses PPPOE. I'm not very technical but from syslog I got to know that the WAN is getting disconnected every now and then. I'm on the latest firmware which is 3.0.0.4.384_32799. My network is pretty simple as I have not customised any settings expect Wireless and PPPOE. Everything else is in its default.
Tried resetting, firmware restore, manual setting after reset but no luck so far.
Below is the syslog, if anyone can understand it and tell me what's wrong. Sorry if it is not everything that you may want, I will be happy to provide and do as per your suggestions. Any help will be much appreciated. Thank you.
Nov 30 15:26:36 pppd[706]: Connection terminated.
Nov 30 15:26:36 pppd[706]: Modem hangup
Nov 30 15:26:40 WAN Connection: Fail to connect with some issues.
Nov 30 15:26:46 pppd[706]: Connected to 0c:c4:7a:8e:af:b2 via interface eth0
Nov 30 15:26:46 pppd[706]: Connect: ppp0 <--> eth0
Nov 30 15:26:48 pppd[706]: CHAP authentication succeeded
Nov 30 15:26:48 pppd[706]: peer from calling number 0C:C4:7A:8E:AF:B2 authorized
Nov 30 15:26:48 pppd[706]: local IP address 10.15.148.61
Nov 30 15:26:48 pppd[706]: remote IP address 103.212.146.1
Nov 30 15:26:48 pppd[706]: primary DNS address 103.56.229.130
Nov 30 15:26:48 pppd[706]: secondary DNS address 103.56.228.140
Nov 30 20:56:48 rc_service: ip-up 2130:notify_rc start_firewall
Nov 30 20:56:49 miniupnpd[1149]: shutting down MiniUPnPd
Nov 30 20:56:49 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Nov 30 20:56:49 wan: finish adding multi routes
Nov 30 20:56:49 rc_service: ip-up 2130:notify_rc stop_upnp
Nov 30 20:56:49 rc_service: waitting "start_firewall" via ip-up ...
Nov 30 15:26:50 WAN Connection: WAN was restored.
seems it lost connection to modem or modem to ISP.
Is you modem in router mode or bridge mode?
If first connect your PC to modem directly and watch if it will loose connection too, maybe your ISP makes some problems or line.
Hi, thank you for your response. I also feel that the issue is with the ISP.
It is in router mode with bare minimal configuration, ie PPPOE username & password and Wifi Enabled. All other settings are in default value.
I can see more than 60-70 disconnections in the last 24 hours, so it is getting into my nerves now. For checking things I connected the internet cable directly to my PC and created a PPPOE connection. I capture packets when the connection was getting terminated. As seen in the attached snapshot, the ISP switch is sending LCP termination request to my Dell PC. Now I don't know why it is sending LCP termination request after random intervals.
I forwarded my findings to the ISP and yet to get a reply from them.
