Asus RT-AC68U weak signal
netguy
Hi folks
I have Asus RT-AC68U and I am having some issues with the wireless range.
I am connected to the router with Asus PCE-AC68 adapter and only getting 70Mbps from a distance of 30ft on the 2.4GHz band and my iphone is not getting signal at all.
I feel that this is not normal and I should be getting a stronger signal.
After doing some research I am considering replacing the device with Netgear nighthawk X4S (R7800) but I am still not sure if that would improve the wireless range.
I need to hear your suggestions and thoughts.
Thanks in advance.
only getting 70Mbps
in what sort of testing ?
and what do you get from the 5 gig band at the same distance as you really should be using 5 gig
totally depends on what construction / materials are in the way between wireless adapter and router
in testing here at 25 meters ( about 80 feet ) through 3 walls and from one end of my house to the other im getting
20MB/s on 5 gig
10MB/s 2.4 gig
using the same router and wireless adapter
until you do some fault finding i would doubt it would improve anything
move router to the same room or comp which ever so both are in the same room and test throughput for both 2.4 gig and 5 gig
you should see
5 gig at around 55 to 60 MB/s
2.4 gig around 25MB/s
doing a file transfer from a ethernet connected device to the comp with the pce-ac68 via wifi
