Release ASUS RT-AX86U Firmware version 3.0.0.4.386.42840
brummygit
Asus look like they have been very busy getting new releases ready for a number of models.
Version 3.0.0.4.386.42840
2021/04/29 73.05 MBytes
1. Fix VPN GUI issues.
2. Improve connection stability.
3. Fix AiMesh related bugs.
4. Minor GUI issue fixes.
5. Upgrade dropbear to version 2020.81
6. Fix buffer overflow vulnerability
7. Fix slowloris denial of service attack.
8. Fix authentication bypass vulnerability.
Please unzip the firmware file first then check the MD5 code.
MD5: 4378ce3da2f4526da11ee42133c6d97f
Thanks for the info.
First impressions on my mesh nodes is positive - I had 2.4Ghz devices unhappy on the previous version, but everything seems to have connected currently.
I have a weird speed-limitation of about 600Mbps with that FW, checked with my fiber company and no changes from their side.
Anyone seen such thing yet?
On previous FW not occurred to me.
I'm getting about 300Mbs slower wired speeds with the latest firmware update. Also using WAN aggregation.
1313.64 down on 4/26/21 at 1:14 PM and today getting 1028.70 down at 11:46 AM.
Getting same here in WIFI issues like you get on Wire
I believe a change they done in the WAN make this happen
Checked Ethernet speed with Chrome Speedtest and looks OK in my case, no issues with that latest firmware for me...
After the upgrade got the message to manually reboot (power cycle) the router…
Has anyone been getting this in the syslog? It seems to be related to adaptive qos. I don't get this in the log when adaptive qos is off.
May  7 08:03:46 kernel: ------------[ cut here ]------------
May  7 08:03:46 kernel: WARNING: CPU: 3 PID: 6200 at net/sched/sch_htb.c:568 htb_qlen_notify+0x78/0x80()
May  7 08:03:46 kernel: Modules linked in: tdts_udbfw(O) init_addr(          (null) -           (null)), core_addr(ffffffbffc15b000 - ffffffbffc160500)
May  7 08:03:46 kernel:  tdts_udb(PO) init_addr(          (null) -           (null)), core_addr(ffffffbffc357000 - ffffffbffc37a054)
May  7 08:03:46 kernel:  tdts(PO) init_addr(          (null) -           (null)), core_addr(ffffffbffd22d000 - ffffffbffd268de8)
May  7 08:03:46 kernel:  thfsplus(O) init_addr(          (null) -           (null)), core_addr(ffffffbffd20b000 - ffffffbffd218084)
May  7 08:03:46 kernel:  tntfs(PO) init_addr(          (null) -           (null)), core_addr(ffffffbffd17e000 - ffffffbffd1ca438)
May  7 08:03:46 kernel:  tfat(PO) init_addr(          (null) -           (null)), core_addr(ffffffbffd129000 - ffffffbffd15a368)
May  7 08:03:46 kernel:  uas init_addr(          (null) -           (null)), core_addr(ffffffbffd120000 - ffffffbffd122140)
May  7 08:03:46 kernel:  usb_storage init_addr(          (null) -           (null)), core_addr(ffffffbffd107000 - ffffffbffd10ac20)
May  7 08:03:46 kernel:  sg init_addr(          (null) -           (null)), core_addr(ffffffbffd0f9000 - ffffffbffd0fd5d0)
May  7 08:03:46 kernel:  sd_mod init_addr(          (null) -           (null)), core_addr(ffffffbffd0eb000 - ffffffbffd0efbd8)
May  7 08:03:46 kernel:  scsi_mod init_addr(          (null) -           (null)), core_addr(ffffffbffd0ad000 - ffffffbffd0bd960)
May  7 08:03:46 kernel:  nf_nat_sip init_addr(          (null) -           (null)), core_addr(ffffffbffd0a6000 - ffffffbffd0a7998)
May  7 08:03:46 kernel:  nf_conntrack_sip init_addr(          (null) -           (null)), core_addr(ffffffbffd09b000 - ffffffbffd09e108)
May  7 08:03:46 kernel:  nf_nat_h323 init_addr(          (null) -           (null)), core_addr(ffffffbffd095000 - ffffffbffd0960e8)
May  7 08:03:46 kernel:  nf_conntrack_h323 init_addr(          (null) -           (null)), core_addr(ffffffbffd083000 - ffffffbffd086a00)
May  7 08:03:46 kernel:  nf_nat_rtsp init_addr(          (null) -           (null)), core_addr(ffffffbffd07e000 - ffffffbffd07e9f0)
May  7 08:03:46 kernel:  nf_conntrack_rtsp init_addr(          (null) -           (null)), core_addr(ffffffbffd078000 - ffffffbffd079188)
May  7 08:03:46 kernel:  nf_nat_ftp init_addr(          (null) -           (null)), core_addr(ffffffbffd074000 - ffffffbffd0742c8)
May  7 08:03:46 kernel:  nf_conntrack_ftp init_addr(          (null) -           (null)), core_addr(ffffffbffd06e000 - ffffffbffd06ec30)
May  7 08:03:46 kernel:  ip6table_nat init_addr(          (null) -           (null)), core_addr(ffffffbffd06a000 - ffffffbffd06a100)
May  7 08:03:46 kernel:  xt_length init_addr(          (null) -           (null)), core_addr(ffffffbffd066000 - ffffffbffd0660f0)
May  7 08:03:46 kernel:  cdc_mbim init_addr(          (null) -           (null)), core_addr(ffffffbffd061000 - ffffffbffd061b48)
May  7 08:03:46 kernel:  qmi_wwan init_addr(          (null) -           (null)), core_addr(ffffffbffd056000 - ffffffbffd056728)
May  7 08:03:46 kernel:  cdc_wdm init_addr(          (null) -           (null)), core_addr(ffffffbffd04f000 - ffffffbffd0508c8)
May  7 08:03:46 kernel:  cdc_ncm init_addr(          (null) -           (null)), core_addr(ffffffbffd045000 - ffffffbffd0471e0)
May  7 08:03:46 kernel:  rndis_host init_addr(          (null) -           (null)), core_addr(ffffffbffd03f000 - ffffffbffd03fb10)
May  7 08:03:46 kernel:  cdc_ether init_addr(          (null) -           (null)), core_addr(ffffffbffd039000 - ffffffbffd039750)
May  7 08:03:46 kernel:  ax88179_178a init_addr(          (null) -           (null)), core_addr(ffffffbffd031000 - ffffffbffd033770)
May  7 08:03:46 kernel:  asix init_addr(          (null) -           (null)), core_addr(ffffffbffd026000 - ffffffbffd028880)
May  7 08:03:46 kernel:  libphy init_addr(          (null) -           (null)), core_addr(ffffffbffd018000 - ffffffbffd01bad8)
May  7 08:03:46 kernel:  cdc_acm init_addr(          (null) -           (null)), core_addr(ffffffbffd00d000 - ffffffbffd00f670)
May  7 08:03:46 kernel:  usbnet init_addr(          (null) -           (null)), core_addr(ffffffbffd001000 - ffffffbffd004000)
May  7 08:03:46 kernel:  mii init_addr(          (null) -           (null)), core_addr(ffffffbffcffc000 - ffffffbffcffcb70)
May  7 08:03:46 kernel:  xfrm_user init_addr(          (null) -           (null)), core_addr(ffffffbffcff0000 - ffffffbffcff4558)
May  7 08:03:46 kernel:  xfrm4_tunnel init_addr(          (null) -           (null)), core_addr(ffffffbffcfec000 - ffffffbffcfec170)
May  7 08:03:46 kernel:  ipcomp init_addr(          (null) -           (null)), core_addr(ffffffbffcfe8000 - ffffffbffcfe8380)
May  7 08:03:46 kernel:  esp4 init_addr(          (null) -           (null)), core_addr(ffffffbffcfe2000 - ffffffbffcfe3270)
May  7 08:03:46 kernel:  ah4 init_addr(          (null) -           (null)), core_addr(ffffffbffcfdd000 - ffffffbffcfde058)
May  7 08:03:46 kernel:  ohci_pci init_addr(          (null) -           (null)), core_addr(ffffffbffcfd9000 - ffffffbffcfd9270)
May  7 08:03:46 kernel:  ohci_platform init_addr(          (null) -           (null)), core_addr(ffffffbffcfd4000 - ffffffbffcfd4800)
May  7 08:03:46 kernel:  ohci_hcd init_addr(          (null) -           (null)), core_addr(ffffffbffcfc7000 - ffffffbffcfcbe28)
May  7 08:03:46 kernel:  ehci_pci init_addr(          (null) -           (null)), core_addr(ffffffbffcfc3000 - ffffffbffcfc3618)
May  7 08:03:46 kernel:  ehci_platform init_addr(          (null) -           (null)), core_addr(ffffffbffcfbe000 - ffffffbffcfbe890)
May  7 08:03:46 kernel:  ehci_hcd init_addr(          (null) -           (null)), core_addr(ffffffbffcfaf000 - ffffffbffcfb6768)
May  7 08:03:46 kernel:  xhci_pci init_addr(          (null) -           (null)), core_addr(ffffffbffcfab000 - ffffffbffcfab770)
May  7 08:03:46 kernel:  xhci_plat_hcd init_addr(          (null) -           (null)), core_addr(ffffffbffcfa6000 - ffffffbffcfa6538)
May  7 08:03:46 kernel:  xhci_hcd init_addr(          (null) -           (null)), core_addr(ffffffbffcf83000 - ffffffbffcf92cc8)
May  7 08:03:46 kernel:  bcm_usb init_addr(          (null) -           (null)), core_addr(ffffffbffcf7e000 - ffffffbffcf7e0a8)
May  7 08:03:46 kernel:  usbcore init_addr(          (null) -           (null)), core_addr(ffffffbffcf42000 - ffffffbffcf59f60)
May  7 08:03:46 kernel:  usb_common init_addr(          (null) -           (null)), core_addr(ffffffbffcf3e000 - ffffffbffcf3e208)
May  7 08:03:46 kernel:  dhd init_addr(          (null) -           (null)), core_addr(ffffffbffcdff000 - ffffffbffce86380)
May  7 08:03:46 kernel:  wl(P) init_addr(          (null) -           (null)), core_addr(ffffffbffc723000 - ffffffbffca4fec0)
May  7 08:03:46 kernel:  dpsta(P) init_addr(          (null) -           (null)), core_addr(ffffffbffc6cb000 - ffffffbffc6cdbe0)
May  7 08:03:46 kernel:  cfg80211 init_addr(          (null) -           (null)), core_addr(ffffffbffc67e000 - ffffffbffc6a3170)
May  7 08:03:46 kernel:  igs(P) init_addr(          (null) -           (null)), core_addr(ffffffbffc672000 - ffffffbffc6753c8)
May  7 08:03:46 kernel:  emf(P) init_addr(          (null) -           (null)), core_addr(ffffffbffc669000 - ffffffbffc66b858)
May  7 08:03:46 kernel:  hnd init_addr(          (null) -           (null)), core_addr(ffffffbffc5f4000 - ffffffbffc620bb8)
May  7 08:03:47 kernel:  [last unloaded: nf_conntrack_ftp]
May  7 08:03:47 kernel: CPU: 3 PID: 6200 Comm: tc Tainted: P        W  O    4.1.52 #2
May  7 08:03:47 kernel: Hardware name: Broadcom-v8A (DT)
May  7 08:03:47 kernel: Call trace:
May  7 08:03:47 kernel: [<ffffffc000087398>] dump_backtrace+0x0/0x150
May  7 08:03:47 kernel: [<ffffffc0000874fc>] show_stack+0x14/0x20
May  7 08:03:47 kernel: [<ffffffc000577790>] dump_stack+0x90/0xb0
May  7 08:03:47 kernel: [<ffffffc000093028>] warn_slowpath_common+0x98/0xd0
May  7 08:03:47 kernel: [<ffffffc000093108>] warn_slowpath_null+0x18/0x20
May  7 08:03:47 kernel: [<ffffffc000428538>] htb_qlen_notify+0x78/0x80
May  7 08:03:47 kernel: [<ffffffc00041e69c>] qdisc_tree_reduce_backlog+0xac/0x140
May  7 08:03:47 kernel: [<ffffffc000429034>] htb_delete+0x194/0x300
May  7 08:03:47 kernel: [<ffffffc00041e9e4>] tc_ctl_tclass+0x2b4/0x2f8
May  7 08:03:47 kernel: [<ffffffc000405940>] rtnetlink_rcv_msg+0x98/0x208
May  7 08:03:47 kernel: [<ffffffc000438f14>] netlink_rcv_skb+0xc4/0xf8
May  7 08:03:47 kernel: [<ffffffc00040589c>] rtnetlink_rcv+0x14/0x20
May  7 08:03:47 kernel: [<ffffffc0004387f0>] netlink_unicast+0x150/0x228
May  7 08:03:47 kernel: [<ffffffc000438cc0>] netlink_sendmsg+0x2f8/0x358
May  7 08:03:47 kernel: [<ffffffc0003d5f70>] sock_sendmsg+0x18/0x58
May  7 08:03:47 kernel: [<ffffffc0003d6ae4>] ___sys_sendmsg+0x26c/0x280
May  7 08:03:47 kernel: [<ffffffc0003d93a0>] __sys_sendmsg+0x40/0x80
May  7 08:03:47 kernel: [<ffffffc000418ad0>] compat_SyS_sendmsg+0x10/0x18
May  7 08:03:47 kernel: ---[ end trace 477c8d52d81dd1e8 ]---
Yes - I also get these log entries but it seems there is no impact ... - I've already sent them to Asus...
Another "minor" fix is that you can now change the icon for clients in Guest 1 WIFI. Custom icons also work.
Same here, lowered to ~700mbits while previously had ~950 with ISP's 1gbit plan
Firmware 3.0.0.4.386_42840 cut my WiFi speed in half on 5Ghz and the speed test in the firmware stopped working.
I am running the RT-AX86U
I tried turning off QoS, did a hard reset with holding down the WPS button and it did not fix it.
So I went back to firmware 3.0.0.4.386_42095 and now I have full speed back with speed test working.
Seems something is wrong with this firmware.
