ASUS RT-BE92U
  • Thread starter Thread starter Deleted member 77025
  • Start date Start date
No, that doesn't change anything, you are copying the old settings then recopying them back. The whole point of this factory reset is to start out new with the new feature set.
Which presumably means you also need to factory-reset all of your AIMesh client nodes and join them back in?
If you mean AiMesh nodes like other ASUS routers and RPs the easiest way is to go to the Management (tab) and Remove each one one by one until all are gone. Then following factory reset add them back one by one. It is easier than trying to hold the WPS flipping on the power, waiting for the power light to turn off, then flipping off and on power switch on each node...
Hi all, I got BE92U with merlin software from 1 month everything seems working stable, but i got question about speed.
PC ( ethernet 1Gbps ) - got full speed from speedtest.net 900/300 Mbps
but my mobile devices ( wifi ) got only a half of that speed.
S25 ultra ( wifi7 mlo ) - 500/300
other phones ( wifi6 ) - 450/300
notebooks are even slower ( wifi6 ) - 350/300
meanwhile when i run iperf3 test from PC to s25ultra i got full 1gbps speed.
iperf3 test from notebook (wifi6 ) to s25u ( wifi7 ) i got over 1,5Bbps.
So why speedtest.net from mobile devices are so slow? there is potential any problem?
I got MLO turn on, Qos off and i using Diverion.
Thx for any advices
Thx for any advices
Try turning MLO off.
I try turning off MLO fronthaul for clients and wifi 7 on network tab, and still the same speeds. My S25U got wifi 6E connection and max speed test is 450/300mbps
That is strange that you can max your connection over wired, but cannot over your WiFi 6E and 7 devices. While you are trying to troubleshoot, do not use MLO, as was mentioned. Connect a couple of your fastest wireless devices to the 6Ghz band, leaving WiFi 7 enabled on each band on the router. Make sure the wireless devices are close to the router, and then reset your internet speed with the speedtest.net app (not mobile browser). If still an issue, disable QoS if enabled, reboot router and try again. Make sure your 6Ghz channel is set to auto on channels and 20/40/80/160/320 Mhz is selected so your wireless devices can negotiate at the fastest speed. If still a problem, DL Ubiquiti WiFiman app, open app, hit signal at bottom and tell us what the PHY Speed (Mbps) is (the negotiated speed).
Have you messed with any of the more advanced settings? If so, you may want to ensure that the firmware is up to date, reset the route to factory defaults, re-setup your wireless networks, but do not change any settings and leave all the Asus features off, no MLO, 3 separate networks for 2.4, 5 and 6Ghz, all with WiFi 7 enabled, then test again.
With an S23 with wifi 6e close to the router, in the WiFiman app, I am at 2161/1921 Mbps negotiated speed and can max my 500/500 connection, as I get 570/540Mbps. I run my BE92U with no MLO, all Asus features disabled like Ai Mesh, Ai Protection, QoS, Traffic Analyzer all off.
on S25U i got PHY speed over 4xxx/24xx and 320mhz. still my speedtest.net app is limited to 500.
I try used iperf3 for testing wifi limit and when i try runing server on notebook ( wifi 6 ) and reciver on S25U i got speed 1,5gbps so wifi speed its ok, but my internet speed over wifi is limited to 500Mbps ( on ethernet its going full speed 900Mbps )
I was dont changing any advanced settings, only got newest merlin software and enabled diversion.
everything is off Ai Mesh, Ai Protection, QoS, Traffic Analyzer
Ofcourse all the test is close to the router.
Edit
All my mobile devices got this slow internet over wifi problem.
I try other test than speedtest.net / app all the same limited speed.
Edit
I've not seen anyone else on this thread with the Merlin firmware. So, that could very well be doing it. Unfortunately, you won't know until you roll it back to the newest Asus FW, reconfigure it and test.
I had the latest Merlin Firmware on my unit and i have an old RT-AC66U B1 with latest stock firmware on my 1º floor, the uplink is via 5ghz wifi (impossible to do an ethernet uplink) was slower on Merlin and the internet speed was also lower. With Merlin on the i mesh unit on the same spot, same wifi channel i had at most 150mbs of internet speed (my internet speed is 500 mbs) and now with latest stock firmware i have about 220/250 mbs wich i think is not bad for 12 year old hardware. Still trying to figure out if i should replace the RT-AC66U B1 with the RP-BE58, my budget is very limited...
220/250 should be fine for a couple ordinary clients and a bunch of IOTs. Not blazing fast, but good enough.
The radio is the limiting factor in the AC66UB1. But if your clients don't need a newer radio to talk with ( especially IOT devices), no issue.
Thx for any advices
I gave up testing with phone/tablets. Since its random every time you test. Its time and server issue than router or device issue. I have S25U, Tab S8, Tab S10U, Xiaomi 12T Pro. I get different max speed depends on what time and server I choose to test with. If I choose a specific server to test with and get 800 down and choose another server and then get 300 down only. Most of the time I only get max 300-500 down. So I stopped caring about testing the speed on devices I have.
I see these are on sale now for under $200. I had purchased three of them last week, at $220, and got a price match. But, I might buy a fourth one since the price is so low now. And have all four setup in a mesh network, instead of just the three I originally planned. I plan to set them up over the Thanksgiving holiday weekend.
I have over seventy devices on wifi, so I figure with more Mesh nodes it can't hurt. I used to run two TpLink 6Ghz 2x2 APs(but I hate the UI), a few years ago. And that worked out well. So I'm hoping theses BE92U units work out well too. I really just want a mesh network where all the devices are the same. And has the Asus GUI. Which is much, much more versatile and better than the Verizon and TP-Link devices I have used. This will be my fourth 6Ghz network setup. So, hopefully, I won't need to upgrade for a few years.
My first one used three FiOS 4x4 6Ghz routers as APs. Then I switched to two 6Ghz TP-Link Archer AXE7800 routers as APs. And then two Asus 4x4 ZenWiFi Pro ET12 units. But, since I have more wireless devices than four years ago, I might go back to having three units plus the router. Which would now be a four unit mesh network.
if your router/nodes are too close together, you will likely create an environment with too much radio power and thus cause more issues for yourself. In the consumer world, more is often not better, even if you have "more" devices using the radio.
I can just turn the transmit power down. I've used four Access Points, plus a router, in the past with excellent results. I just decreased the transmit power to the middle setting. Instead of the highest. So, hopefully, that will also work with a mesh setup.
Right now my AP mesh, with two ZenWiFi Pro ET12 units, are on the highest transmit power setting.
The ET12 units are only using 5Ghz and 6Ghz. While my RT-AX89X router is only using 2.4Ghz.
I plan on using all three bands with the mesh network. I just need to move my SmartThings hubs to new locations. Because they won't work when next to my APs or router outputting 2.4Ghz. Since it will interfere with the SmartThings 2.4Ghz communication.
AiMesh doesn't have per node Tx power control.
So, are you saying, if I set it to the middle power setting then all the nodes won't change to that setting? If so then how do you adjust the transmit power at all? I would think the power setting, like the other wifi settings, would be the same at each node.
I've never tested it with my AP mesh. But, I do see where I can still adjust the transmit power setting with my AP mesh.
Test your luck and report back.
To me you are replacing better high-end AXE-class equipment with entry-level BE-class with known and expected issues. Investing money in improvements on paper is unlikely to improve user experience. Just because you found something cheap doesn't mean you have to jump in. With wired infrastructure you have better options than consumer mesh. Your choice.
I run a 10 Gigabit backbone. And have around 150 devices on my network. Around 70 or so are wireless and the rest are wired.
The lower level devices for WiFi6E worked great for me in the past. I'm just hoping the newer WiFi7 devices will also work well.
I really hated the interfaces of the other devices. Which is why I went through so many devices over the last four or five years.. The Asus interface is so much better. And I also want all my devices to be the same model. Which makes it easier to manage. Which is also another reason I am switching to something newer.
With the BE-92U now being out for over a year, and the lower sale price, it seemed like something for me to try. If I do have issues I can return those BestBuy purchases up until the end of January. If I do run into issues then I might ZenWiFi BT10 three pack. The current sale has it around the same price as four of the BE-92U routers. But, it also doesn't have many ports. And no 2.5GbE ports.
My plan now is just to run the BE-92U units with a 2.5GbE connection. And run them all to the 2.5GbE ports in the Primary BE-92U. And then I will run the 10GbE port to an 8 port 10GbE switch. Which will feed my other switches, on the wired part of my network.
With all the feedback about the BE-92U, I just might go ahead and purchase the ZenWiFi BT10 3 pack while it's on sale. So I will have it just in case I need it. But, ideally I would just stick with the BE-92U models.
