Asuswrt-Merlin 3004.388.10 Beta is now available for supported devices. The focus of this release is the merge of an updated GPL, and the backport of a few new features from 3006.102.
Please keep discussions on this specific release. Off-topic posts will be either ignored or deleted.
Downloads are here.
Changelog is here.
3004.388.10 (xx-xxx-2025)
- NOTE: For developers, please note that the new default branch
is now called "main" - it's what was previously the
3006.102 branch.
The "master" branch has been renamed "master-old", and
is no longer actively used. Due to how the 3006.102
branch diverged, it was easier to do it this way than
to fold back 3006.102 on top of master.
3004.388 remains where 3004.388 models live.
- NOTE: Due to numerous webui changes, it's recommended to
force refresh the page after first login, or clear
your browser cache.
- NEW: Completely redesigned System Log -> Connections page.
- You can now filter the list
- You can set the page to auto-refresh itself
- Public IP addresses can be looked up on
WhatismyIPaddress.com
- Local hostnames will be resolved and shown
- Routed IPv6 connections will be shown
- NEW: Added Control-D servers to DNS-over-TLS
presets (dave14305)
- UPDATED: Merged GPL 388_25523.
- UPDATED: dropbear to 2025.88.
- CHANGED: Setting DNS Director to "Router" will now always
redirect to the router's own IP. Previously it
would redirect to the first DNS server configured
on the DHCP page (which defaults to the router
itself).
If you need DNS Director to redirect to an IP
configured in your DHCP settings, use a Custom DNS
entry in DNS Director. This makes it more consistant
with what the name implies, and was also necessary
for improved Guest Network support.
- CHANGED: Replaced netstat-nat by a fork called netstat-nat-ng.
This fork fixes a number of issues with IPv6 and
field size.
- CHANGED: Optimized performance when refreshing the Sysinfo
page on a network with thousands of tracked
connections.
- CHANGED: Modified the Quick Internet Setup wizard so not
to attempt downloading firmware updates from Asus
(which would fail anyway).
- CHANGED: Tools category renamed System Info.
- CHANGED: Tools -> Other Settings were moved to new tabs
(Administration -> Tweaks, and
Traffic Analyzer -> Settings).
- CHANGED: Moved "Redirect to asusrouter.com" to the new
Tweaks tab, and moved "Enable JFFS Custom Scripts"
to the Basic Config section on the System page.
- FIXED: DNSDirector "Router" mode would not always work properly
with IPv6 (now uses REDIRECT instead of DNAT, which was
backported from iptables 1.4.19).
- FIXED: Additionnal fix for the status frame missing from
Network Map under certain hostnames.
Downloads are here.
Changelog is here.
