Release Asuswrt-Merlin 3004.388.10 is now available
But, But, But, But, ... when will the ASUS phone App get updated? ☺️
The fewer routes into the router the better and especially through an app. Remote access through VPN Server is such a better idea, if remote access really is that necessary. And for local access, 192.168……, through a browser is ideal. I’d call the failure of app access a blessing. What do you reckon?
Totally agree, only problem pretty much no features work in the app now 😬
The changes are too inconvenient for me. Login via https is fine, but being forced to log into the router on my home network without giving me a choice—no thanks. And then there's the malfunction with the Asus mobile app! So I downgraded the main router to the old firmware version 388.9.2! Now my problem is solved—and maybe for a longer period of time, too, since I want to buy the Strix GSBE18000.😁
I agree. Especially for a third party developer working on a free independent solo project. I find it rude that so many make demands with the Me Me Me attitude.
I can't update my Ax88u from version 388.9_2. Whenever I try to update the router, it's the same version above. I've already made several attempts, without WAN connected, without the node , only lan, without any connected equipment, I've already given hard reset, I tried Chrome, edge and nothing. Do you know if there is another way?
When you say hard reset, have you tried a power cycle first? (pull barrel end out while leaving power switch on, wait a minute for unit to drain and then plug back in) Flash as soon as you can, no usb devices attached.
EDIT:You may need the WAN connected for NTP and have the LAN plugged into a Yellow port.
Already! I turned off the router, held the wps button until the light flashed, then I turned it back on, then it asked to start the new connection, but it doesn't have the option to update directly, so I reconfigure it, I try to update and it won't work. It seems that there is something blocking because my node is updated and it was also in version 388.9_2. Do I have to disable something? Scripts installed: cakeQos, amtm, merlimAU.
Cake might be issue, also try the update via merlinAU. See my edit above?
Yes, I just tried once again with the WAN connected, I tried to go back to FW Stock ASUS, but it doesn't continue, it gets stuck in version 388.9_2
Actually unplug for 5Min, not power off?
All working fine on AX11000. Thanks again.
Use the ASUS Firmware Restoration Tool version 2.1.0.3:
You should be able to Flash RMerlin, without having to go to stock first. You just need to be 100% on correct firmware, RT-AX88U.
I tried, but it says that a wireless device in recovery mode was found. What intrigues me the most is that the first time I can't update my router was in this version 388.9_2. All other previous versions were always normal without the need to do anything.
Are the nodes off / unplugged?
EDIT: Keep nodes on stock firmware, and they will need to be flashed and Reset after the main unit is flashed correctly. Do them independently.
Are the nodes unplugged?
The node is in the latest version of Merlin (388.10). So do I need to go back to Stock firmware and try to do it again?
I've already removed the node, I've already left it plugged in and nothing to update.
New password rules were slightly loosened for Asuswrt-Merlin, repeating characters are still allowed.
Can someone please tell me what the new password requirements are, and if they are enforced immediately or only when the pw is next changed? I will wait to update if they are enforced immediately -- too many devices and users teach the new pw.
Thanks!
The node cannot be connected while trying to flash with the Recovery Tool.
Leave the node alone for now, but powered off.
