Beta Asuswrt-Merlin 3006.102.4 Beta is now available
The manual assignment of IP addresses doesn't seem to work here , when assigning then to an MAC address through the gui.
Working fine here. Same firmware, same router - but I use YazDHCP.
Working for me as well, and I also use YazDHCP.
The ones that were already assigned remained in place after the upgrade from 3004
And I added a couple of new ones after the upgrade.
Seems to be working fine on a RT-AX86U Pro, also running YazDHCP. The manual IP assignments for Guest Network Pro clients, in the Guest Network Pro Profile Advanced Settings, is also working.
Seven days issue free operation! Looks like this beta is golden on the large scale of things for basic functionality. Thanks for all your guys development on this. I send over a small donation the other day to keep your coffee coming.
MLO still not worth using. (Not Merlin)
BSD still doesn't play nice with Apple or Enterprise controlled devices. (Not Merlin)
Don't worry about the port log seen here, I have an old wireless light controller that just seems to reset its port every 24 hours. I have tried everything short of getting a newer model but the behavior is not causing any issues and is not a router based problem, either.
I have Samsung S23U,iPhone 12 Pro Max, Honor Magic V3, iPad mini 5, Mac Studio M2 Max and one PC laptop running Windows11. Only Samsung S23U can connect perfectly to BE92U MLO, both speed and transmission distance is better than 6GHz, while other devices have all kinds of problems when connected to MLO. For examples slow, disconnect issues and sometimes causing the BE92u running not stable and need to have reboot. (Merlin and original firmware result the same)
Which router?
After a firmware update of my AiMesh nodes last night, all is back to normal
Which router?
Sorry I was super busy at work didn't see your question. I see you found it. Anyways, what's the benefit of YazDHCP? I looked at the addon but I didn't see any benefit to using it over the native Merlin package.
YazDHCP About:
Feature expansion of DHCP assignments using AsusWRT-Merlin's Addons API to read and write DHCP assignments, increasing the limit on the number of reservations.
One of the big features is to be able to export manual DHCP reservations and reimport them at a later time, Iike after doing a hard factory reset followed by manual configuration. Or when updating from one Asus merlin supported router to another, transferring the manual DHCP reservations to the new router.
YazDHCP About:
To copy dhcp_staticlist from jffs/nvram is another option
