Beta Asuswrt-Merlin 3006.102.4 Beta is now available
Yes there is a problem with this beta for the amtm add on's . I hope there is a way to fix this. I you can't no one can 😉
I don't see any problem. What exactly are you seeing?
RT-AX86UPro router running 388.8_4 for 111 days with no issues (no mods, etc).
Node is an RT-AX3000 v1 running 388.9_2 with no issues.
Decided to jump directly (dirty update) to 3006_102.4_beta2 on the router after a fresh reboot. Done. Let it settle a half hour or so and after never using a Guest Network, finally wanted to set up a VLAN for my 25 or 30 IoT devices, all of which are 2.4G. The notes say "If migrating from a 3004 firmware, only the first Guest Network will be migrated" but that did not apply to me since never having one. I read through as many threads here on this and after fiddling around briefly with a few IoT's, I never could get them all to stay connected to the VLAN. Some kept showing in the 2.4G section while others were in the correct IoT network. This would occur using either the Pre-defined IoT Network or choosing Custom Config and unchecking "use same subnet" box. And the devices near the node never got picked up even though they were in the same room or close nearby. Forcing a bind on the node would result in "signal too weak" but clicked OK anyway. I could then click the reconnect button and some would then cooperate. Deleting and re-adding the node did not make any difference either.
For now, I deleted the VLAN and changed the few IoT devices back so everything is as it was before and the node once again sees the nearby devices.
Can‘t fix when I don‘t know what to fix.
I haven't run into any issues either—everything works just fine for me. But with countless different configurations out there, there's always a chance that something might not work for someone.
So, who am I then? decoderman?
Anyway, is there a problem with amtm in his beta version? I have no way to test it.
I am having no problems with amtm on my AX88Pro running Beta 2.
I have a problem with Adguard and when I am trying to update the amtm scripts with the u commando the all give an error with the update. Adguard is not usable because dnsmasq is crashing when I look at the logs in my router. I just use only one guest SSID for guests. In the other group I and others have this already mentioned.
In other words, not an amtm issue.
No not the amtm but the add on's. But do you now who can fix this?
Beta 3 is now available. Changes since beta 2:
Wifi 7:
40adf8f5d5 Bump revision to 3006.102.4 beta 3
b4d835a202 Updated documentation
9b75a69006 webui: Add Control-D servers to DoT json database
10a2737649 webui: fix DDNS notification bell on main index page
c37ffe2268 webui: update policy handling for Boostkey support; remove GT-AC2900 boostkey handling
29a6b7677a webui: re-add option to hide DHCP/RA queries, lost in the 102_36216 GPL merge
8ea42a46d7 webui: minor chart tweaks to Sysinfo
879c3d2f13 webui: move option to enable custom scripts to the Basic table; remove dead JFFS2-related code
ab1d87aaf4 Move "Redirect webui access to www.asusrouter.com" setting to the new Tweaks page
bae1c058a9 webui: rework Tools menu
ce67ba47a7 httpd: fix get_header_info returning truncated hostnames in certain scenarios
b63d4eaab6 webui: Ignore ASUS remote DoT json database on Multiservice WAN page
513a8a715d Updated documentation
f1f82d8e56 lighttpd: backport fixes from 102_37526
8d7f3bb437 rc: implement DOT blocking for SDN with DNS Director enabled
32df2f61de rc: make Global DNSDirector rule use REDIRECT target instead of DNAT
Wifi 6 additional changes:
1b846fdb30 webui: Escape single and double quotes in key/SSID on Wireless page and networkmap Wireless frame
1585de5f04 libmnl: fix invalid symlinks for installed library
amtm has been the MOST stable of all so called "Add-ons" - and no doubt one of the major reason for its inclusion in all Merlin firmware.
I am running this beta and have not had even a hint of a problem with running updates ["u" option] from with amtm on my GT-AX6000.
@Apul - please open a new thread and explain your problem clearly - this forum provides the best support of any I have ever been a member of under any topic. 🤩.
I feel a release coming...my bones are telling me it's imminent...mayhaps as soon as this weekend...
(actually we're ~30 pages deep on a beta release page and experience dictates this is about when)
Beta3 just making an appearance in the downloads - just did dirty upgrade over Beta2. Will report if there are any issues.
Beta3 rock solid for me - enjoy the webgui reshuffles as well - makes sense 👍
Performed a dirty update to beta 3—no issues to report. The new System Info and Tweaks split looks good; I think this arrangement makes more sense.
Updated from beta2 to beta3 on my BE92U.
Now this is all I see on the Network Map (index.asp) screen.
If I click the buttons that are visible, it does nothing.
I have to enter the address of another screen (/Advanced_OperationMode_Content.asp) for example to see the usual info/options.
