Beta Asuswrt-Merlin 3006.102.4 Beta is now available
Updated from beta2 to beta3 on my BE92U.
Now this is all I see on the Network Map (index.asp) screen.
If I click the buttons that are visible, it does nothing.
I have to enter the address of another screen (/Advanced_OperationMode_Content.asp) for example to see the usual info/options.
confirmed, updated beta 2 to beta 3, seeing the same thing
After seeing this screenshot, I also notice that there is no icon for System Info on BE92U.
Flush your cache - you are still using the older CSS from your cache.
@RMerlin B3 initial looks ok, thus far. Thx!
No UI issues here either, everything is displayed correctly.
Brand new BE96u bought last weekend to replace my non-pro AX86u. Immediately loaded beta 2 out of the box.
Only issue I kept running into was my gigabit internet speeds kept dropping throughout the day both download / upload, but... I also have a New ISP provider that I'm using and it does not appear to be router related from what I can see as my AX86u when I plugged it back in again to test a few times exhibited the same behavior. Last 3 days internet speeds are holding steady.
- IOT VLAN created
Also, seems like all my IOT devices stay connected and are extra snappy -- no more YazFi script needed either
Loaded Beta 3 - All seems to be working well. Pretty impressed with the BE96u so far and merlin firmware makes this baby purr. So far so good.
Loving my new toy, now to figure out if there's a way to give priority to one VLAN over another...
Keep up the good work!
Yes that is done and the icon is now visible.
It's the main index page that is the only issue.
Can confirm the Network Map UI issue on the RT-BE92U. Same issue as @Ev0 Have also flushed cache etc. with no effect. Router operates normally and other pages are OK.
BE92u updated to Beta 3 same issue. no effect after flushing cache and delete cookies.
It seems that only Network Map page got issues. I have to enter the URL manually to go other pages.
Router running without issues after upgrading to beta3
BTW does anyone know what these log means?
May 4 09:29:37 kernel: fifo_bitmap_by_startidx:
May 4 09:29:37 kernel: 0000: 04 00 00 00 00 00 00 00
May 4 09:35:07 kernel: fifo_bitmap_by_startidx:
May 4 09:35:07 kernel: 0000: 04 00 00 00 00 00 00 00
Thanks Merlin.
This didn’t merge nicely into the BE92 branch.
That is odd - one line was inserted too low. Pretty sure that merge was done automatically through a git merge from 3006.102 on top of the RT-BE92U branch, so not sure what happened there. The "git diff" of that commit even looks correct.
I just recompiled a fixed version. The new archive is called "beta3b", but the firmware version itself will be unchanged. If the index page loads properly, then you know you're on the fixed version.
Network Map display fixed. Thanks so much Merlin.
Clear your browser Cache and reload...
Edit: When i got to reading this page, it was allready solved .... LOL
Thanks @RMerlin for new firmware version. Everything is working fine on GT-AX6000 but there’re some words need to fix:
Monitoring Settings vs Tools - Other Settings
System Info vs Tools - System Information
Thx RMerlin, all good again now.
Ya, have observed some light browser cache cosmetic browser render related issue(s). For example, Network Map -> Ethernet Ports -> images for ports may not load / show if clicking away and back on to it. Page reload (browser refresh) brings it back.
On Administration - Firmware Upgrade page in the upper right the "bell" symbol keeps flashing telling the is an updated version of the firmware. I have Beta 3 loaded and the Check for New Firmware is turned off. Even if I do the Check for update it tells me there is no newer version, but the "bell" at top right keeps flashing saying there is. Did not happen with Beta 1 and 2. Have cleared browser cache, reloaded webpage and rebooted router. No change. Have Asus RT-AX86u Pro (Edge browser).
No such issue on an RT-AX86U Pro that I manage remotely (using Firefox browser).
There was an updated Firmware for the AiMesh router an Asus RT-AX-86u. I updated the firmware for it, but it's still telling me there is a new Firmware ("Bell" at upper top right still flashing). Cleared cache, all that.
Well I have no idea, but it seems to have somehow as by magic fixed itself.
