Release Asuswrt-Merlin 3006.102.6 is now available
I bit the bullet last week on a new rt-be92u from UK Currys (£169). Came on Friday, I immediately put this latest firmware on and then setup mostly from scratch, I copied some of the NVRAM pieces over (Wireguard Server/Clients, DHCP reservations and names). It was working fine, although coming from a rt-ax92u, I noticed it is quite laggy on the webGui, with pages not always refreshing.
The strangest thing was I set a 1am Sunday reboot. I was up early and found no internet. I logged into the router at 5:11am and was surprised as it had an assigned WAN address from the ISP, so it was either routing table not updated or something else. PPPoE connection directly to a ONT over ethernet.
a restart of the WAN (click WAN on/off in Gui) fixed it.
See attached logs. I have obfuscated mac/ip/usernames
Any ideas on cause. I have disabled auto-reboot for now.
Disable IPv6 in your DDNS settings and reboot.
Thanks Ill start doing that. However, issue returned this morning. Windows 11 most up to date devices are not consistently being shown when connected to 6Ghz bands. I can go in and force a refresh and they come back for a bit but then they disappear again after a while. Not sure what's causing the issue but Ill like have to roll back a couple versions to check the behavior. I don't see anything in the debug log to indicate what's happening.
I have seen the same on BT10 (stock!!).
My investigations:
You have a multi-band network (5 and 6GHz)
You have disabled MLO completely (on 'Wireless', 'MLO').
If I enable MLO globally (on 'Wireless', 'MLO'). then they are shown correctly.
Note: You don't need to enable MLO backhaul on ANY networks.
Please try that and report back.
I think Asus is so keen on MLO that they have forgotten not everybody uses it.
Don't know if its the right place to post a bug, but this version on the AXE-16000, while in Adaptive QOS and trying to drag down the "Highest, High, Medium, Low, Default, etc" buttons, I get a window message box that pops up, "Max Limit:: 32".
Dirty Flash from 102_5
Yes, that’s a new,y enforced limit. But those priorities don’t do anything anyway unless you’re using Traditional QoS.
My investigations:
Yoooooooooooooooooooooooo, someone just get this man a coffee! This fixed the issues I was having with wifi 6 not showing in front menus and some weird performance dips I have been seeing on this version. MLO doesn't provide ANY benefits in any of my testing 6Ghz + 320Mhz is working better at normal distances from the router.
Good morning. First time poster, long-time user here.
I registered to mention that I've encountered a problem after update to 102.6 on my GT-AX6000. It's happened for the first time in three years of using it, even though I've always been doing dirty flash update.
The problem occurs in Openvpn server that is operating there; after approximately two hours of firmware's update, openvpn server stopped working. The only relevant message that the log had for me was:
Rich (BB code):
Nov 29 22:17:16 Mastiff: Got SIGTERM
Nov 29 22:17:21 ovpn-server1[23748]: event_wait : Interrupted system call (fd=-1,code=4)
and the subsequent info in Openvpn's server tab was "awaiting to initialize files" (or similar). Turning the server off and on again on that tab seemed to fix the issue, but it died again after two hours and a change. Router's reboot has not fixed the issue, so I returned to 102.5 and it's been working properly for three days and counting.
I assume the core reason for that incident was dirty flash upgrade, but I've been doing those countless times on many Merlin-driven devices through the years with no issues, so I thought it would be worth describing here.
Really bad idea, I only drink tea :D
Seriously, this is definitely an Asus bug, not related to Merlin.
Does anyone else consistently get weird issues with the GUI? On this version and the previous, i've had pages load where it looks like it was from a previous firmware, have to refresh the page a couple times for the real one to appear. This one takes the cake though, what is this? RT-AX86U Pro
On my RT-BE88U fw3006.102.6, i have 1 primary, 1 Child and 1 IOT Wifi VLAN and activating MLO always results into driver crash, past few hours :
Dec 2 05:15:35 kernel: CONSOLE[wl0]: wl0: reason = mac suspend failure at 25829 seconds. corerev 134 ucode revision 1892.42722 features 0x9106
Dec 2 05:15:35 kernel: CONSOLE[wl0]: psmdebug 0x1ff0016 pc 0x1ff0016 phydebug 0x1 macctl 0x84160402 maccmd 0x4
Dec 2 05:15:35 kernel: CONSOLE[wl0]: psm_brc 0x0120 psm_brc_1 0x4000 M_UCODE_DBGSwl0: AAP: linkid = 1
Dec 2 05:15:35 kernel: CONSOLE[wl0]: wl0: reason = psm watchdog at 25829 seconds. corerev 134 ucode revision 1892.42722 features 0x9106
The router attempt to restart wifi but fail :
Dec 2 05:16:19 kernel: pcieh 0001:01:00.0: swiotlb: coherent allocation failed, size=41943040
I have to restart wifi manualy to retrieve wifi access.
Any one else have same issue ?
Rich (BB code):
I use the same router GT-AX6000 and have not experienced the OpenVPN Server issue you describe. Mine is now and has always been rock steady under Merlinware. I use it frequently for family mobile devices which are set up to always route via the Home Server VPN so they enjoy not only better security - but also the ad free experience provided by that wizard known as @thelonelycoder [Diversion].
Sorry - not much help I know - but you may need to do a factory reset and manual reconfigure. The issue can't be with the firmware itself [or LOTS of folk would have experienced the same]. Did you factory reset after upgrading from 3004.388 software versions? - I did as a precaution and always do with major version releases such as the jump from 3004.388 to 3006.10?
Issues with /opt and read-only filesystem on GT-AX6000 after Merlin dirty upgrade
Router Model: ASUS GT-AX6000
Firmware Version: Merlin 3006.102.6_0
Hi everyone,
I’m experiencing issues with my GT-AX6000 after performing a dirty upgrade of Merlin firmware. Here’s the timeline of what happened:
  1. After the dirty upgrade, I could no longer log in to the web GUI.
  2. SSH login was still working, so I tried various troubleshooting steps with the help of ChatGPT.
  3. Eventually, I reached a state where I couldn’t log in via SSH either.
  4. I had to perform a factory reset using the physical reset button on the router.
After resetting:
  1. I reconfigured the router and started using AMTM.
  2. I formatted my USB drive (labelled usbkey) and began installing packages: Diversion, Skynet, RTRMon, Wicens.
  3. While installing tailmon, I encountered a problem: I couldn’t write to /opt (or other locations) because the filesystem is read-only.
Current situation:
  • /opt is still a symbolic link pointing to tmp/opt.
  • Attempting rm -rf /opt or recreating the symlink fails with “read-only filesystem.”
  • Manually mounting the USB works (/tmp/mnt/sda1), but linking it to /opt is blocked due to read-only restrictions.
  • All troubleshooting with scripts in /jffs/scripts (post-mount) hasn’t solved the issue yet.
What I need help with:
  • Understanding why /opt cannot be modified on this firmware after a factory reset.
  • Correct procedure to set /opt to the USB drive for Entware on GT-AX6000 Merlin.
  • Any tips to make package installations (Diversion, Skynet, Tailmon, etc.) work without hitting read-only filesystem errors.
I hope someone with more experience on the new Merlin release can advise.
Thanks in advance!
Hi everyone,
After resetting:
Current situation:
Thanks in advance!
Sounds like a failed USB drive to me...
ChatGPT - first error.
If you truly meant the Reset button, it isn't reset to factory but only reset config (partial at that) - only WPS button reset is a true reset (as via GUI with the checkbox ticked to clear all).
So I would Reset that properly again before any next step...
I also wondered if it was the USB. That’s why I bought a new SANDISK ULTRA FLAIR 32GB, so we can probably rule out the USB.
We can't.
*edit* attach the contents of the fd log ("fdl" in amtm) in a text file.
Install the disk checker ("dc" in amtm). Attach the contents of dcl as a text file, after a reboot.
  • Like
Reactions: MDM
