Ax-89x Beta
ben29
So i run on my router diagnostic to send to Asus
Today i got this email.
Is this legit?
I got this email in the time i did diagnostic from my router with my email .
The from address is:
mark078524@gmail.com
Not from asus
That’s super weird
It's also a little weird that the address of the download is a personal Asus Webstorage account and not the internal Asus FTP servers.
If it is legitimate then the person sending it has done a great job of making it look suspect - and it needs to be treated as suspect IMHO!
Asus using Asuswebstorage for sharing beta firmwares is quite common, as it allows a dev to quickly share it. Let me check with my contacts if this is legitimate, as the GMail address does seem strange indeed.
Might take a while since due to timezone difference, Taiwan's offices are currently closed for the night. I should learn more once they reopen later today.
The point is I really share feedback on my router.
No one can’t know that,
It’s the same deception and model,
And i did factory reset, after that i did feedback
Just wait for a confirmation. It's highly unlikely to be malicious since it was tied to feedback provided, but no harm in waiting for confirmation.
i got the same Download url like here:
https://www.asuswebstorage.com/navigate/a/#/s/75F0803793174F3F81BD6D3EF97D79024
but no one can confirm it's legit
just need to confirm it's legit
i get reply from Asus
Dear Valued Customer,
During routine security maintenance, our technical team discovered an error in the configuration of our server settings file, which could potentially cause an interruption in network connectivity on part of the routers.
Our technical team has urgently addressed the server issue and impacted routers should return to normal operation. If your device was affected, we recommend the following:
  1. Manually reboot your router
  2. If rebooting does not resolve the issue, please save the settings file, perform a hard reset (factory default), and then re-upload the settings file (follow the directions in the https://www.asus.com/support/FAQ/1050464)
  3. If you cannot access the user interface to save settings or perform a reset, you can press the RESET button for about 5-10 seconds until the power LED indicator on the router starts to blink, which means the reset is completed. https://www.asus.com/support/FAQ/1000925/#m2
If there are any further developments around this issue, we will immediately update our users.
We deeply apologize for any inconvenience this incident may have caused and are committed to preventing such an incident from happening again.
Thank you for your understanding and support.
i send email to " Mark " and ask who is.
that's the reply.
that's the reply.
I received confirmation that the firmware did come from Asus's RD, and is safe to use.
can you share with me the confirmation?
There's nothing for me to share. A manager at Asus told me this firmware indeed came from someone on his team, and I'm repeating it here.
B ASUS 89X - Slow WiFi ASUS Wireless 7
