AX59U: Problem with Adaptive QoS when VPN server is on
GhostProtocol
Hello everyone, I have problem using the Adaptive QoS while also using IPSec VPN server on my router.
If VPN server is turned on, the adaptive QoS bandwidth caps doesn't work at all. I have set Download Bandwidth and Upload Bandwidth limits, but when VPN Server is turned On and QoS set to adaptive mode with bandwidth caps, these caps are not respected, they just simply don't work. If I turn off the VPN server, caps work again as it should, then I have no problems. But immediately after turning the VPN On, the issue persists.
This doesn't happen while using traditional QoS. If i have set VPN to On and QoS to Traditional then caps are respected and working fine.
Anyone else facing same issue?
This device is MediaTek hardware based and not very popular around SNB Forums, mostly focused on Broadcom hardware devices with Asuswrt-Merlin support. My suggestion is to report the issues you are experiencing directly to ASUS in available Feedback Form.
