Bandwidth caps per device
questinghero
Is there a way to use QOS or anything else to cap bandwidth (not prioritize) on the RT-AC87 per device? we don't have cable, so my kids watch netflix instead of cartoons. well Comcast has me set with a 300GB cap (I know I can buy 50GB buckets for $10... but it is hard to justify to spend more on cartoons). I could do this on my last router with dd-wrt, but merlin seems to be the only firmware available for this router right now (and other then this issue, I think it is amazing).
I have looked thorough the forms and I have seen this asked before but it has been awhile. is there a different firmware that I could try.
Thanks,
It's probably possible with merlin, but you would probably need to setup a script to implement an iptable configuration.
I think Android and iOS both have bandwidth capping capabilities, so maybe you could limit bandwidth at the individual devices?
It's the PS3 that is the biggest culprit. No bandwidth capping available there. I think I am going to put my old dd-wrt router back into play and just use the Asus as an ap. Not my favorite option, but I can't find a better solution.
You could browse the dd-wrt source-code and see what commands it is running to achieve the per-client bandwidth capping and see if merlin's firmware supports the same capabilities, which it should, unless you're running a 3.x kernel dd-wrt.
Thanks,
I have exactly the same problem. I just use the parental controls to restrict the devices my kids watch cartoons on to an hour or so on the weekends. A bandwidth cap per device would be nice though. This is how Comcast sticks it to cable cutters like us.
I took a look at how DDWRT does it.
They have a function that handles client connections, in that they make a call to a QoS function thats adds an iptable rule for the ip of the device connectioning with the up/down per ip rates.
So a clunky alternative could be to set up a script that loops through all possible ip addresses (based on the LAN ip range) and adds an iptable rule for each, address - not a clue on any performance implications.
You could rely on the device's MAC instead of their IP address for better reliability.
Anybody willing to write me a script that would do this (or at least show me how)? I put my old router back in play last night (with the Asus in AP mode), it works great, but I would love to have just one device
