[Beta] Asuswrt-Merlin 380.64 Beta is now available
RMerlin
Asuswrt-Merlin dev
Staff member
Asuswrt-Merlin 380.64 Beta is now available for all supported models.
The highlights of this release:
  • New firmware availability notification. You will now be notified on the webui when a new firmware is available for download, and will be shown the changelog, as well as a button bringing you directly to the download folder for your specific model. Note that you must still manually download and flash the firmware.
  • Updated components with nano, OpenVPN and Curl updated to their latest versions
  • Tor will now route all TCP traffic, not just web traffic.
  • The QoS Statistic page will now automatically refresh, allowing you to monitor your QoS traffic as it occurs.
  • You will notified when your available nvram becomes too low.
  • Performance enhancements to the webui (better caching of some Javascript files)
  • Fixes to the webui for Firefox: broken App popup, broken client list on some pages.
Things that need to be tested specifically:
  • Please test the webui with Firefox. While two issues were tracked and fixed, I'm unsure if it took care of all the Firefox-specific issues (some of which are random)
  • Feedback regarding the performance of the webui: any visible difference? Anything newly broken since 63_2?
  • There's an experimental change related to USB HDD handling at shutdown. Does it resolve HDD detection issues that appeared in 380.63_2?
A few notes regarding the new version notification system:
The check is run every 48 hours, or whenever the router is booted. New final releases will display the flashing notification icon at the top of the webui, however new beta releases won't trigger that icon.
The check can manually be triggered from the Firmware Update page. If you check the "Check Beta version" box before clicking on the Check button, then the router will check for any new alpha or beta release. It will NOT check for the presence of a newer non-beta release however, you have to uncheck the Beta box and re-run the manual check for that. Note however that the router will still always check for non-beta releases as part of its scheduled check.
The check code used is the same as used by Asus, where a small text file is downloaded, containing a list of models and available firmware versions. Your router will then locally scan that file, looking for any new release for its specific model.
One change from Asus's code is that I do not support live updating over the Internet. You must manually download, unzip and flash your router like before (the Download button on the Changelog popup will at least take you directly to the correct folder). I have no intention of implementing a live update capability, for many security reasons.
There is no notification outside of the webui (i.e. no email notification) at this time. Part of why is because Asus seems to be working on a revamped notification subsystem for a future firmware. Since I do not know what are their plan for this new notification system, I'd rather not waste my time developing something they might no longer work or become redundant in the near future. If down the road they end up not adding any Email notification capability, then I will consider possibly implementing one (but no promises).
Downloads are here.
Changelog is here.
Known issues:
  • Disabling new firmware checks will remove the setting from the webui. (Fixed).
Just uploaded beta1 on my 5300. No problems whatsoever. Fast refresh and fast page loading. I am using Vivaldi as my browser. Ipv6 also working as expected!
The check did find the new firmware and it took me to the RT-AC68U page. (Then went to beta folder.)
I use Firefox all the time and the WebUI seems pretty snappy. It kept my Traffic Statistics this time since I changed it to a USB thumb drive a few days ago (which it found again). The App pop-up seems to display fine (never messed with it before). My client list never had any more than three devices so not much to test there.
HTTP webui is way, way faster. I like this update a lot. However, after firmware update from 380.64alpha3 to beta1 on AC68U, web browser says that my router's certificate is not valid(on Alpha3, I imported certificate to Chrome and Windows), so I will probably re-import certificate to my PC. Will I have to re-import router certificate every time I update firmware? Or is it just this version?
Thank you, btw, for developing such a perfect custom firmware.
https certs changing not specific to this version. There is a way to save them to nvram and restore after firmware change and factory default, so you can get green padlock in your favourite browser. I'm sure there is a thread here, but here is a link which should give a clue of the nvram vars used:- https://gist.github.com/davidbalbert/6815258
My own selfsigned certificate is working just fine after the upgrade to Beta 1.
Thank you for pointing that out. I haven't rebooted during Alpha3 so I didn't notice. I found this link which works for me, in case someone else come looking: http://www.snbforums.com/threads/do...te-change-with-each-reboot.34554/#post-279267
In my case Firefox complained about it in the last ~10% of the update, but it was OK again once the update was finished.
Flashed the beta to my AC3200. GUI is definitely much faster. Haven't seen any gremlins yet.
Router: RT-AC68U
Just upgraded from 380.63_2 to 380.64_beta1-geced399 . Early yet, but poking around a bit in the webgui after the upgrade I'm not seeing any config issues, nor performance issues thus far.
I almost always use Firefox (with many extensions) on Linux Mint 18 MATE 64-bit to do admin on the router. This new beta 'seems' to be a bit snappier, although I never really had any issues in Firefox before with asuswrt-merlin in the webgui. And yes, the 'App' link works now in Firefox (but I don't use a smartphone).
I don't use QoS. I'll monitor the new firmware version checking functionality.
@RMerlin Hey man. I'm going to attempt to modify your RT-AC68U build to include the required modules from the Asus DSL-AC68U source code. What's your build environment? You using Ubuntu 16.04 32bit or 64bit env?
Looking closer at my daily Traffic Stats, they seem to be about .2 Gig above what my ISP thinks and what the Traffic Analyzer Statistics page says. I do have NAT acceleration turned off.
More an observation than anything. I wonder what extra bits the Traffic Monitor is counting that the other two don't?
I have a RT-68U rev B and loaded the Beta1. It loaded without issue and seems to be working great. I enabled Traditional QoS and saw one oddity. CPU 1 and 2 stay above 60% and are mostly above 90%. So I turned off QoS and the load didn't change, so I rebooted. It still is showing very high CPU usage. I say it's odd because normally I do not see them vary much above small spikes and steady around 5% or less. No issues just oddly much higher CPU usage.
I ssh'd into the router and bwdpi_sqlite is using 50% of the CPU.
Wiggy! My ram usage is steadily increasing.. started around 50% and now is at 85%
It went up to 90% and then dropped down to 65%.. then slowly works it way back to 90% over around 3 minutes. This cycle keeps repeating.
I flashed back to 380.63.2 and the issue is gone, back to 2% cpu and 56% memory. I will try another flash to Beta1 tomorrow or later tonight when the rest of the house is sleeping.
Might be rounding errors...
Would you consider making live updating optional? It would be nice to install for grandma and not have to worry about it again.
RMerlin has his reasons, and I agree with him - sometimes things change enough that it might require a reset of some/all settings, and this would put a huge amount of risk in some use cases...
Not sure what he's using... An alternative package (which is in entware) is vnstat - it's what I use to track my usage...
realtime data from a few minutes ago - the one downside I see with vnstat is that it does write once a minute, so not good to keep it on the NAND, this would have to be on an external mount...
$ vnstat
                      rx      /      tx      /     total    /   estimated
 WAN (igb0):
       Nov '16    229.07 GiB  /    7.55 GiB  /  236.61 GiB
       Dec '16     59.04 GiB  /    1.83 GiB  /   60.86 GiB  /  195.53 GiB
     yesterday      5.39 GiB  /  162.63 MiB  /    5.55 GiB
         today      2.92 GiB  /  131.42 MiB  /    3.04 GiB  /    4.69 GiB
 LAN (igb1):
       Nov '16     10.82 GiB  /  212.00 GiB  /  222.82 GiB
       Dec '16      2.79 GiB  /   54.00 GiB  /   56.78 GiB  /  182.43 GiB
     yesterday    246.56 MiB  /    4.87 GiB  /    5.11 GiB
         today    205.21 MiB  /    2.67 GiB  /    2.87 GiB  /    4.42 GiB
$ vnstat -h -i igb0
 WAN (igb0)                                                               15:30
  ^        r
  |              r                                                     r
  |     r        r                                                     r
  |     r        r                                                     r
  |     r        r                                                     r
  |     r        r                                                     r
  |     r        r                                                  r  r
  |     r        r                                                  r  r
  |     r        r                                                  r  r  r
  |     r  r  r  r  r                                   r  r     r  r  r  r
  |  16 17 18 19 20 21 22 23 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15
 h  rx (MiB)   tx (MiB)      h  rx (MiB)   tx (MiB)      h  rx (MiB)   tx (MiB)
16      89.06       3.03    00      18.10       0.74    08      57.62       2.99
17    1002.29      22.06    01      15.18       0.61    09     139.82       4.71
18     212.29      17.31    02      14.68       0.63    10     197.84       4.50
19     182.69      11.24    03      15.95       0.66    11      19.95       1.09
20    1123.57      44.96    04      14.95       0.63    12     209.46      11.93
21     143.68      10.93    05      36.48       1.47    13     538.21      28.55
22      15.67       0.94    06     103.11       1.52    14    1206.74      47.35
23      15.29       0.83    07      22.69       1.76    15     331.94      20.25
$ vnstat -d -i igb0
 WAN (igb0)  /  daily
         day         rx      |     tx      |    total    |   avg. rate
      11/11/16     14.30 GiB |  418.87 MiB |   14.71 GiB |    1.43 Mbit/s
      11/12/16      6.27 GiB |  451.64 MiB |    6.71 GiB |  651.50 kbit/s
      11/13/16      3.68 GiB |  131.92 MiB |    3.81 GiB |  370.13 kbit/s
      11/14/16     12.04 GiB |  385.73 MiB |   12.41 GiB |    1.21 Mbit/s
      11/15/16      4.89 GiB |  179.90 MiB |    5.06 GiB |  491.66 kbit/s
      11/16/16      7.18 GiB |  273.20 MiB |    7.45 GiB |  722.92 kbit/s
      11/17/16      5.66 GiB |  201.85 MiB |    5.86 GiB |  568.63 kbit/s
      11/18/16      5.55 GiB |  178.49 MiB |    5.72 GiB |  555.33 kbit/s
      11/19/16      9.34 GiB |  411.76 MiB |    9.74 GiB |  945.45 kbit/s
      11/20/16     14.86 GiB |  391.63 MiB |   15.24 GiB |    1.48 Mbit/s
      11/21/16      8.76 GiB |  279.98 MiB |    9.03 GiB |  877.19 kbit/s
      11/22/16      5.21 GiB |  194.23 MiB |    5.39 GiB |  523.80 kbit/s
      11/23/16      2.46 GiB |   97.74 MiB |    2.56 GiB |  248.37 kbit/s
      11/24/16      3.77 GiB |  122.67 MiB |    3.89 GiB |  377.74 kbit/s
      11/25/16      5.82 GiB |  134.75 MiB |    5.95 GiB |  577.61 kbit/s
      11/26/16      8.43 GiB |  259.92 MiB |    8.69 GiB |  843.57 kbit/s
      11/27/16      7.47 GiB |  314.80 MiB |    7.78 GiB |  754.97 kbit/s
      11/28/16      7.46 GiB |  161.31 MiB |    7.62 GiB |  739.87 kbit/s
      11/29/16     27.34 GiB |  480.62 MiB |   27.81 GiB |    2.70 Mbit/s
      11/30/16      5.66 GiB |  211.50 MiB |    5.86 GiB |  569.14 kbit/s
      12/01/16      3.18 GiB |  109.71 MiB |    3.29 GiB |  319.14 kbit/s
      12/02/16      4.87 GiB |  148.93 MiB |    5.01 GiB |  486.50 kbit/s
      12/03/16      6.04 GiB |  333.29 MiB |    6.37 GiB |  618.34 kbit/s
      12/04/16      6.99 GiB |  281.10 MiB |    7.27 GiB |  705.80 kbit/s
      12/05/16      4.36 GiB |  206.86 MiB |    4.56 GiB |  442.51 kbit/s
      12/06/16      3.65 GiB |   97.31 MiB |    3.74 GiB |  363.45 kbit/s
      12/07/16     12.67 GiB |  228.36 MiB |   12.89 GiB |    1.25 Mbit/s
      12/08/16      8.97 GiB |  172.16 MiB |    9.14 GiB |  887.08 kbit/s
      12/09/16      5.39 GiB |  162.63 MiB |    5.55 GiB |  539.17 kbit/s
      12/10/16      2.92 GiB |  131.42 MiB |    3.04 GiB |  455.25 kbit/s
     estimated      4.49 GiB |     201 MiB |    4.69 GiB |
$ vnstat -w -i igb0
 WAN (igb0)  /  weekly
    last 7 days     44.91 GiB |    1.25 GiB |   46.15 GiB |  674.27 kbit/s
      last week     61.55 GiB |    1.69 GiB |   63.23 GiB |  877.03 kbit/s
   current week     37.91 GiB |  996.72 MiB |   38.88 GiB |  668.68 kbit/s
      estimated     47.18 GiB |    1.21 GiB |   48.39 GiB |
$ vnstat -m -i igb0
 WAN (igb0)  /  monthly
       month        rx      |     tx      |    total    |   avg. rate
      Aug '16    224.15 GiB |    8.37 GiB |  232.52 GiB |  728.25 kbit/s
      Sep '16    228.74 GiB |    7.77 GiB |  236.51 GiB |  765.43 kbit/s
      Oct '16    223.60 GiB |    6.07 GiB |  229.67 GiB |  719.30 kbit/s
      Nov '16    229.07 GiB |    7.55 GiB |  236.61 GiB |  765.76 kbit/s
      Dec '16     58.99 GiB |    1.83 GiB |   60.82 GiB |  612.19 kbit/s
    estimated    189.60 GiB |    5.87 GiB |  195.46 GiB |
