Broadcom BCM6756 VS Mediatek filogic830 which CPU router is better?
pingpong
BCM6756 is cortex A7 1.7Ghz ( 4 core )
Ex. Asus ax3000v2
Filogic830 is cortex A53 2.0Ghz ( 4 core )
Ex. Asus tuf AX4200
1. Which one is better cpu?
2. Cortex A7 is equal to what? A53? A73? B53?
3. Any other suggestion to buy not over 200 usd router good CPU? please suggest a few ^^
Note: I like to use more in LAN 1/2.5 G is all ok
thank you
Cortex A7 is an older armv7 generation than Cortex A53/B53 which is armv8.
However the router's CPU power has very little impact on router performance (unless dealing with gigabit WAN), you should focus on other aspects of the specs.
thank you so much
