Cannot SSH to router
keef
I have an Asus AXC88U and I cannot SSH into it. I am using Putty on both a Windows box and a Linux box. The connection times out. Internet wise the router is working fine. I have SSH enabled, LAN only, pwd login enabled and the port # is correct. I have rebooted several times (switch and unplug the power cable) and reset the router to factory defaults still with no luck.
I am using Merlin 388.1 and I am open to any ideas!
thanks
Crimliar
Idea no.1: If you are going through a YazFi setup guest SSID you won't be able to connect to the router's WebUI, because security...
*Tripped over this last night trying to replicate a different issue.
dave14305
Part of the Furniture
You don’t have any Access Restrictions enabled at the bottom of the Administration / System page?
keef
I was doing more looking around and I cannot ping the router. This is getting weird. I turned the f/w off and still nothing. This has never happened to me.
dave14305
What name or IP are you using? Are you certain it’s correct?
SSH is enabled, LAN only, the port matches, and pwd login is enabled.
Thats not what I’m asking about. At the bottom ”Remote Access Config”…
keef
Jus5 in case it is this issue is only In a certain version of Merlin. I downgraded to 386.8
dave14305
Under Network Tools, run the netstat with the options shown and confirm the router IP is listening on port 22.
