Can't connect Merlin OpenVPN client to Pivpn server.
xGMBx
Good morning all,
Attempting to connect a remote AC5300 (384.19) to my Pi 3B+ pivpn (OpenVPN) server.
Using Android/windows 10 Openvpn client I can import the .ovpn file and I'm up and running without issue. (Ports are all open and the server is definitely functional)
This is just a test user, but the log is telling me -> TLS Error: TLS handshake failed.
I've tried with and without a password, still "Error - check configuration"
Here are two screen caps of my settings and the log output.
Log readout
My settings
Any suggestions would be much appreciated.
Thanks!
Through more testing I now realize it's a port issue, I just don't know why. Forwarded the port on router, I check the UDP port using IPfingerprints.com and it shows open|filtered on UDP but I can't connect anywhere outside my LAN. I can't get Wireguard to connect either. DMZ made no difference, I have another router connected using PPPOE directly to my Modem/Router that was issued it's own IP address from my ISP so maybe that's causing some type of interference.
Thanks to anyone who read my initial question.
I have the same issue. everything worked well on 384 as soon as I upgraded to 386, I could not connect to PI anymore. With the error Check configuration.
If anyone can help. Here is the log file... This is after a factory reset and reloading the exact same ovpn file.
I downgraded back to 384 in the meantime.
I can see 3 errors in the log file: Cypher, SSL, Name Check...
