Can't find Turbo QAM setting
Rey
Hi everyone,
sorry if this is a dumb question, I did some searching and couldn't find an answer. I have seen in rickygao blog on how to optimize the router an option to enable Turbo QAM but it seems to be mission on my router. I am running RT-AC66U router on Merlin 380.59 firmware. Has the option to enable it been removed from this firmware version or am I doing something wrong? Thanks in advance.
Indeed, the RT-AC66U doesn't have support for that feature. If you really want/need it, you'll have to upgrade to at least the AC68U
You mean upgrade at least to a RT-N18U, RT-AC56S or RT-AC56U, those are less expensive devices supporting Turbo QAM.
Thanks, didn't know these support TurboQAM
No problem, yw.
I did not see any mention of TurboQAM in my AC56U running Merlin 380.58.
TurboQAM in 2.4GHz doesn't offer much, and can cause interoperability issues with legacy clients... I usually recommend it to be disabled if the AP supports it...
Thanks for the help everyone. I was going crazy trying to find the setting but now it makes perfect sense.
