Create PPPoE session via command line
OmniWired
I need help to connect a second PPPoE session using the same WAN port.
Then, get ip + dns from ISP DHCP and set this second session as IPv6 default gateway.
Is this possible with Merlin vanilla or I need to install extra opkg?
Thanks, my router is an ASUS RT-AC87u
This seems like something that RMerlin firmware isn't (easily) capable of, if at all. I think DD-WRT is a better path to take here.
It would help to know what router you have though.
My router is a Asus RT- AC87U, I don't think I can go with DD-WRT since this router chipset is broadcom.
