Crypto Settings
nosfaay
I'd like to change Crypto Settings to maximize vpn bandwidth, I tried these parameters but I can't connect to vpn server with it :
Data ciphers : AES-128-CBC:AES-128-GCM
TLS control channel security : Outgoing auth (1)
Auth digest : SHA1
I get this error:
Nov 30 14:23:16 ovpn-client1[25967]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Nov 30 14:23:16 ovpn-client1[25967]: TLS Error: TLS handshake failed
I try to get how it works but I'm a bit lost.
ColinTaylor
Part of the Furniture
You need to match the crypto settings used by the server. Do you control the server?
octopus
Auth digest : SHA1
I get this error:
You can test to change between Data ciphers : AES-128-CBC:AES-128-GCM there should be some difference. Maby AES.128 GCM is faster, just test.
