Custom cron job
privacyguy123
If I'm right I see erros in the logs about the ? in this cron statement because it is "non standard"
What is the correct way to run something every 45 seconds?
crond[1618]: user admin: parse error at ?
0/45 0 0 ? * * *
Perhaps this may help:
The lowest you can go is once every minute.
*/1 * * * *
NAT-PMP keep port open script.
For such cases where you want to run some task/cmds with a frequency < 60 sec., you can write a shell script in which you set up a while loop that encloses the desired tasks/cmds followed by the interval delay. I have done this before when reading from a FIFO pipe that was set up by another process, and because the FIFO buffer is rather small I had to read it every 2 seconds or so.
Here's a rough draft of what the script would look like:
Bash:
#!/bin/sh
# RunTaskEveryXseconds.sh
# Run some task/cmds every X seconds until told to exit.
set -u
# Set interval between runs #
intervalSecs=30
ScriptFName="${0##*/}"
LockDirPath="/tmp/var/${ScriptFName%.*}_d.LOCK"
ExitSemFile="/tmp/var/${ScriptFName%.*}_f.EXIT"
_ReleaseLock_()
{ rm -f "$ExitSemFile" ; rm -fr "$LockDirPath" ; }
_AcquireLock_()
   if mkdir "$LockDirPath" &>/dev/null
   then return 0 ; else exit 1 ; fi
trap "_ReleaseLock_; exit 0" HUP INT QUIT ABRT TERM
_AcquireLock_
echo "Entering while loop..."
while true
do
   echo "[$(date)]: Run some task/process every [$intervalSecs] sec."
   ## Run desired task/cmds here ##
   if [ -f "$ExitSemFile" ]
   then echo "Exiting while loop." ; break ; fi
   sleep "$intervalSecs"
done
_ReleaseLock_
exit 0
#EOF#
Then you can run the script in the background from one of the hook scripts (e.g. services-start) depending on the requirements or needs of the process or set of commands you're trying to run.
Bash:
/jffs/scripts/RunTaskEveryXseconds.sh &
My 2 cents.
