1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Custom firmware build for R7800 v. 1.0.2.64SF
Discussion in 'NETGEAR AC Wireless' started by Voxel, Feb 22, 2019.
Tags:
  1. Voxel
    Voxel Very Senior Member
    Dec 9, 2014
    1,040
    Continuation of
    https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-63sf.54782/
    New version of my custom firmware build: 1.0.2.64SF.
    Changes (vs 1.0.2.63SF):
    1. Attempt to fix the issue with ReadyCLOUD in AP mode.
    2. Default ReadyCLOUD version is upgraded 20170914->20180619.
    3. Fixing the issue with OpenVPN server (WebGUI).
    4. OpenVPN is upgraded 2.4.6->2.4.7.
    5. tar package is upgraded 1.30->1.31.
    6. curl package is upgraded 7.63.0->7.64.0.
    7. unbound package (used in stubby) is upgraded 1.8.3->1.9.0.
    8. getdns package (used un stubby) is upgraded 1.4.2->1.5.0.
    9. stubby package is upgraded 0.2.3->0.2.4.
    10. libsodium package (used in dnscrypt-proxy v.1) is upgraded 1.0.16->1.0.17.
    11. libvorbis package is upgraded 1.3.5->1.3.6.
    12. ffmpeg package is upgraded 3.2.12->3.4.5.
    13. busybox package: patch command is added.
    14. busybox package: dos2unix/unix2dos commands are added.
    15. Host tools: two components are upgraded (bison, sed).
    The link is:
    https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
    P.S.
    Maybe I release fw too often :). But a lot of updates. And new version of OpenVPN: it worth a try.
    Voxel.
    JeffA, zeljko1234, MinkyMomo and 23 others like this.
  2. ulaganath
    ulaganath Senior Member
    Jan 12, 2015
    440
    Gr8 I have to share this.
    It’s been 2months your 62f is rocky.
    I was Also using a mini router but x4s is also a router maybe overkill but I like the interface of edge x live traffic system which is missing in x4s I know the 3rd part app will give that.
    My experience is afterR7000 this router has reached near gig internet speed I was literally getting 118+ even local speed limit to 108-115MB/s
    It’s good experience my setup ready for future internet . Of course a lot of factors involved a good cpu and app with good ram and SSD needed for this speed to be achieved constantly I mean a 50gig will be downloaded full 1gbps speed wow post snap and video as possible.
  3. ulaganath
    Jan 12, 2015
    440
  4. pege63
    pege63 Very Senior Member
    Jan 17, 2015
    922
    Sweden, AngelIsland
    NO, just keep up with the good work Voxel!!
    Tom_Batty and Voxel like this.
  5. kamoj
    kamoj Senior Member
    May 12, 2017
    281
    I'm very happy for the busybox additions.:)
    Now I have more to do this weekend.;)
    Thank you Voxel!
  6. Voxel
    Dec 9, 2014
    1,040
    He-he! Funnily kamoj . They are added especially. To load your weekend ;). People like your work! Go ahead.
    Voxel.
    Tom_Batty and kamoj like this.
  7. cordezz
    cordezz Occasional Visitor
    Feb 12, 2018
    25
    Thank you Voxel.
    I can confirm that it works now. Had to type first “cloud uninstall” and reboot, but then I could register my Readycloud account. :)
    BTW: Whats the difference between entware-cortex-a15-3x-initial-generic.tar.gz and entware-cortex-a15-3x-initial-alternative.tar.gz ?
    kamoj and Voxel like this.
  8. Voxel
    Dec 9, 2014
    1,040
    Good you could solve this. I had something similar during testing. Something was changed in the stock 1.0.2.62 for AP mode. So I had to add my own init script for ReadyCLOUD installation. And BTW people in official NG forum signal problems with ReadyCLOUD (in bridge mode, but the same for AP mode).
    See:
    https://github.com/Entware/Entware/wiki/Alternative-install-vs-standard
    Alternative is important for some packages such as e.g. OpenSSH server (it does not accept root account rights for init script).
    Voxel.
  9. cdysthe
    cdysthe Regular Contributor
    Sep 22, 2013
    131
    Great new build! And no, you do NOT release too often. Those who do not want to update simply shouldn't. Thank you so much for your excellent work! My router purrs every time I get a new Voxel on it! :)
    Murtaza12, kamoj and Voxel like this.
  10. vit5421
    vit5421 Occasional Visitor
    Nov 7, 2018
    31
    There is a bug in this version. The router is working after update but password and security questions were lost on both routers and i have to reset the routers and upload the configuration file
    So be careful
  11. kamoj
    kamoj Senior Member
    May 12, 2017
    281
    The OpenVPN Client speed is again the best I ever seen with Voxel Firmware: 120+ Mbps after 10+ tests to www.speedtest.net.
    Congratulations Voxel!
    PS
    I have not lost "my password".
  12. vit5421
    Nov 7, 2018
    31
    It happens on my both routers for 1st time ever. So i guess there is a problem
  13. Voxel
    Dec 9, 2014
    1,040
    I think you are mistaken. Maybe you flashed this version from the version < 63SF (or stock 1.0.2.62). Since 1.0.2.63SF I added NG's security enhancement (taken from the stock 1.0.2.62). And it asks for a password by design. Passwords are not stored now in nvram as a plain text so it is why it asks your for a password and security questions.
    I've flashed both of my R7800 and first of them four times. No lost passwords.
    I think guys would already report this (a lot of reports) in the case of such a bug.
    Voxel.
  14. vit5421
    Nov 7, 2018
    31
    Thank you. I flashed 64sf from 63sf. 63sf flashing was good. It works fine now after reset. The security questions was lost as well on both routers and I can't even activate telnet. I hope it was just my problem then
  15. ulaganath
    Jan 12, 2015
    440
    Still rocking[​IMG]
    Sent from my ASUS_Z01RD using Tapatalk
    L&LD likes this.
  16. bartj12
    bartj12 New Around Here
    Feb 23, 2019
    1
    Thank you so much for your rock stable firmware!! Upgrading costs like 5 minutes, so keep the updates coming!
    Voxel likes this.
  17. cdysthe
    Sep 22, 2013
    131
    I did not experience the password loss. I have been getting the request for setting a new more secure password though, but that was before the update. All good here.
    kamoj likes this.
  18. jsmiddleton4
    jsmiddleton4 Senior Member
    Dec 3, 2012
    493
    No DNS lookup stalls so far.
    Will install kamoj's scripts/add in later and see after doing so.
  19. jsmiddleton4
    Dec 3, 2012
    493
    Don't know what to tell you just that with kamoj's add in for me I have DNS stalls. Takes too long to resolve.
    Also I lost connection to my USB/eSATA attached hard drives.
  20. billygoat
    billygoat New Around Here
    Feb 23, 2019
    1
    I wanted to show some thanks so donated a little for your hard work. Thank you for your firmware and more importantly your attitude towards newcomers.
    Voxel, cdysthe and kamoj like this.
