D-Link DIR 655 vs DIR 628
Q
QBA
Guest
Hi guys,
I'm looking to buy a new router and I found these two D-Link DIR 655 vs DIR 628, for a similar price at a local store.
What do you guys think is the overall better router out of the two?
Alex
Your choice is basically gigabit ethernet and faster routing performance (DIR-655) vs 5 GHz support (DIR-628).
Unless you intend to run a 5 GHz-only network, the 655 would probably be a better choice.
Thanks jdabbs,
Which of the two has more range?
I don't really do a lot of networking between the computers, maybe a few small files once every two weeks.
Which of the two routers will be better for VOIP? I will connect the voice over IP router behind one of those routers.
I'm using this cordless 2.4 Ghz phone from Panasonic, that promises a Wireless network friendly built in capability to avoid interference from Wi-fi networks and microwave ovens.
I guess that if this "Wireless network friendly in capability" works, I shouldn't have to worry about running a 5Ghz betwork vs a 2.4 Ghz to avoid interference. So having a 5 Ghz to avoid interference maybe shouldn't be something to take into consideration, right?
The 628 underwent a revision a few months ago that replaced the radio, so the performance data here may not reflect what you buy today. However, both devices use Atheros radios and feature 2 dBi antennas. I would expect range to be similar with the performance advantage going to the 655 as it is a 3T3R design. Performance also lies in your choice of client, so you may not be able to take advantage of a potential performance difference anyway.
Both use Ubicom CPUs, so QoS should be identical.
You are describing the ability of your phone to handle interference. This is a separate function from its ability to cause interference. If your phone allows you to manually set a channel, then you can work around the issue.
Since range is the first thing your reply brought, it's probably important to you. Although moving to the 5 GHz band allows you to escape from interference in the 2.4 GHz spectrum, the use of a higher frequency results in reduced range. You exchange one problem for another.
Thanks a lot for such a detailed reply,
I have one last inquiry:
Can use the DIR 268 in the 5 GHz frequency without interrupting the communication with my 2.4 GHz wireless print server?
Or this pretty much take away the argument of using the 5 GHz feature on the DIR 268, therefore making the DIR 655 a clear winner?
The 628 can only operate in one band at a time, so for 5 GHz operation you would need another device for your 2.4 GHz devices. The router you are using now may be do the trick.
There's a performance penalty for having your 11g and 11n clients share the same AP. Your print server wouldn't be much of a problem unless it is particularly chatty, but your other 11g devices may be. Then again, you may just be looking for a "better" router, and not be too concerned with wringing the last bit of performance out of it.
