stambeccuccio
Using a range extender, I notice that in DHCP there are IP address inconsistencies, in short seems the DHCP router does not operate well and in any case there is confusion.
Adding an extender creates confusion in DHCP, between pages:
- System Log - Wireless Log
- Network Map - Client status
- Network Map - View List
- LAN - DHCP Server
In addition I ask:
- why you can not see devices attached to the range extender? You only can see the number of devices, but not which devices.
I think it would be more useful to see devices connected, considered that the extender range performs its pure function and not use its own DHCP.
In addition:
- the router does not offer the ability to decrease the lower roaming assistance at a value less than -70 dBm
- the ASUS service (which I do not remember the name) that recognizes the MAC address does not work well
- LAN - DHCP Server
- Roaming assistant
Thanks for the attention
stam
- LAN - DHCP Server
In addition I ask:
In addition:
- LAN - DHCP Server
- Roaming assistant
stam
