Jack-Sparr0w
On or off on home network,
dnsmasq
that disallow a host on the LAN claiming wpad
as it network name.Personally I wouldn't make those changes to my PC just because I was using a VPN. You're already sending all your browser data though the VPN service and trusting them with it. Preventing a hypothetical wpad interception in that circumstance seems a bit of a nonsense argument. If you're particularly concerned simply turning off Automatic Proxy Setup in your browser's settings would probably achieve the same thing. I'm not even sure that WPAD would work at all if the VPN client was running on the router rather than your PC.would it be safer to turn off being used with a service like nord vpn on router. small home network with no work connections. this article has been scaring me https://www.thewindowsclub.com/how-to-disable-web-proxy-auto-discovery-wpad-in-windows
Yes, I understand how WPAD works and it's vulnerabilities. You said you were concerned about WPAD when using NordVPN. The threat described by PCworld is not from NordVPN (or any other VPN provider):This article says Man-in-the-middle attackers can abuse the WPAD protocol, The two researchers showed that some widely used VPN clients, like OpenVPN, do not clear the Internet proxy settings set via WPAD. This means that if attackers have already managed to poison a computer’s proxy settings through a malicious PAC before that computer connects to a VPN, its traffic will still be routed through the malicious proxy after going through the VPN. https://www.pcworld.com/article/415...ur-accounts-and-private-data-compromised.html
The threat comes from your LAN having already been compromised. They are just saying that using a VPN client doesn't change that....if attackers have already managed to poison a computer’s proxy settings through a malicious PAC before that computer connects to a VPN..
Thread starter | Title | Forum | Replies | Date |
P | Send stats Division and Skynet to webhook or mqtt | Asuswrt-Merlin AddOns | 0 | |
amtm error - client_loop: send disconnect: Broken pipe | Asuswrt-Merlin AddOns | 2 | ||
T | Diversion dnsmasq.log file empty | Asuswrt-Merlin AddOns | 19 |
Welcome To SNBForums
