dnsmasq-dhcp[1477]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60s)
Jerry Loh
I'm using AX55, but today i see my log flooding. What's wrong? No firewall log, no aiprotection.
Any idea?
Result from
1 - free
total used free shared buffers cached
Mem: 250680 217852 32828 2952 16092 43832
-/+ buffers/cache: 157928 92752
Swap: 0 0 0
2 - df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 26.5M 26.5M 0 100% /
devtmpfs 122.3M 0 122.3M 0% /dev
tmpfs 122.4M 280.0K 122.1M 0% /var
tmpfs 122.4M 2.4M 120.0M 2% /tmp/mnt
ubi1:data 1.0M 64.0K 880.0K 7% /data
/dev/mtdblock9 15.0M 1.6M 13.4M 11% /jffs
3 - ls -lh /tmp
-rw-r--r-- 1 admin root 171 Jun 3 17:10 0C:9D:92:4C:43:58.cap
-rw-r--r-- 1 admin root 372 Jun 3 17:10 0C:9D:92:4C:43:58.json
-rw-r--r-- 1 admin root 59 Jun 5 02:19 0C:9D:92:4C:43:58.port
-rw-r--r-- 1 admin root 70 May 5 2018 24:4B:FE:22:6D:08.cap
-rw-rw-rw- 1 admin root 625.4K Jun 5 02:20 ahs.log
-rw-rw-rw- 1 admin root 1.0M Jun 4 16:18 ahs.log.1
-rw-rw-rw- 1 admin root 14 Jun 4 05:06 ahsjson.json
-rw-r--r-- 1 admin root 491 Jun 5 02:18 allwclientlist.json
-rw-r--r-- 1 admin root 143 Jun 3 00:11 aplist.json
---------- 1 admin root 0 Jun 3 17:11 asusdebuglog_lock
drwxrwxrwx 2 admin root 40 May 5 2018 asusfbsvcs
-rw-r--r-- 1 admin root 0 Jun 5 00:11 blockfile_tmp
drw------- 3 admin root 500 Jun 3 01:01 bwdpi
-rw-rw-rw- 1 admin root 52.8K Jun 5 02:11 ce0.log
-rw-rw-rw- 1 admin root 64.1K Jun 4 15:29 ce0.log.bak
-rw-r--r-- 1 admin root 601 Jun 3 17:10 chanspec_all.json
-rw-r--r-- 1 admin root 138 Jun 3 17:10 chanspec_avbl.json
-rw-rw-rw- 1 admin root 101 May 5 2018 chanspec_avbl.txt
-rw-r--r-- 1 admin root 253 May 5 2018 chanspec_private.json
-rw-r--r-- 1 admin root 959 Jun 5 02:19 clientlist.json
drwxr-xr-x 3 admin root 60 Jan 1 1970 confmtd
-rw-r--r-- 1 admin root 181 Jun 5 02:19 current_wired_client_list.json
-rw------- 1 admin root 27 Jun 3 00:11 ddns.cache
-rw-rw-rw- 1 admin root 3.0K Jun 5 02:19 dev
lrwxrwxrwx 1 admin root 8 May 5 2018 dhcp6c -> /sbin/rc
drwxrwxrwx 4 admin root 80 May 5 2018 diag_db_cloud
drwxrwxrwx 2 admin root 100 May 5 2018 dm
---s--s--T 1 admin root 0 May 5 2018 ebtables.lock
drwxr-xr-x 10 admin root 1.3K Jun 3 00:11 etc
-rw-rw-rw- 1 admin root 828 Jun 3 16:06 filter.default
-rw-rw-rw- 1 admin root 383 Jun 3 16:06 filter_ipv6.default
-rw------- 1 admin root 4.3K Jun 3 16:06 filter_rules
-rw-rw-rw- 1 admin root 88 May 5 2018 guest_vsie
drwxr-xr-x 3 admin root 60 Jan 1 1970 home
-rw-rw-rw- 1 admin root 14 Jun 3 00:27 hw_auth_clm
-rw-rw-rw- 1 admin root 64 May 5 2018 lld2d.conf
-rw-rw-rw- 1 admin root 41 May 5 2018 lldpd_bind_ifnames
-rw-r--r-- 1 admin root 43 Jun 3 19:36 maclist.json
-rwx------ 1 admin root 1.9K Jun 3 00:19 mangle_rules
-rw-rw-rw- 1 admin root 5 May 5 2018 mastiff.pid
-rw-rw-rw- 1 admin root 0 May 5 2018 mastiff_log
drwxrwxrwx 2 admin root 40 Jan 1 1970 mnt
lrwxrwxrwx 1 admin root 28 Jun 3 16:06 nat_rules -> /tmp/nat_rules_ppp0_eth0.500
-rw------- 1 admin root 615 Jun 3 16:06 nat_rules_ppp0_eth0.500
drwxrwxrwx 2 admin root 180 Jun 3 00:12 nc
drwxrwxrwx 2 admin root 40 May 5 2018 netool
-rw-r--r-- 1 admin root 11.5K Jun 5 02:16 nmp_cache.js
drwxr-xr-x 3 admin root 60 Jan 1 1970 notify
-rw-rw-rw- 1 admin root 1 May 5 2018 obstatus
-rw-rw-rw- 1 admin root 88 May 5 2018 obvsie
drwxrwxrwx 3 admin root 300 May 5 2018 ppp
srwxrwxrwx 1 admin root 0 May 5 2018 ps_sock
-rwx------ 1 admin root 2.6K Jun 3 00:19 qos
-rw-rw-rw- 1 admin root 18 Jun 3 00:11 rast_stc_idx0
-rw-rw-rw- 1 admin root 18 Jun 3 00:11 rast_stc_idx1
-rw-rw-rw- 1 admin root 785 Jun 3 16:06 redirect_rules
-rw-rw-rw- 1 admin root 111 Jun 4 05:19 release_note0.txt
-rw-r--r-- 1 admin root 343 May 5 2018 relist.json
-rw-rw-rw- 1 admin root 38 Jun 3 00:11 resolv.conf
-rw-rw-rw- 1 admin root 30 Jun 3 00:11 resolv.dnsmasq
-rw-rw-rw- 1 admin root 264 May 5 2018 run_lldpd.sh
-rw-r--r-- 1 admin root 0 Jan 1 1970 settings
drwxr-xr-x 2 admin root 40 Jan 1 1970 share
-rw-rw-rw- 1 admin root 204 Jun 5 02:00 sig_upgrade.log
-rw-rw-rw- 1 admin root 0 Jun 5 02:12 syscmd.log
-rw-rw-rw- 1 admin root 968 Jun 5 02:19 syslog.log
lrwxrwxrwx 1 admin root 8 May 5 2018 udhcpc -> /sbin/rc
-rw-rw-rw- 1 admin root 10 May 5 2018 udhcpc0.expires
-rw-r--r-- 1 admin root 101 Jun 4 21:41 upnp.leases
drwxr-xr-x 4 admin root 80 Jan 1 1970 var
-rw-rw-rw- 1 admin root 0 Jun 5 02:20 watchdog_heartbeat
-rw-r--r-- 1 admin root 237 Jun 3 17:10 wchannel.json
-rw-r--r-- 1 admin root 367 Jun 4 05:19 webs_ispinfo.json
-rw-rw-rw- 1 admin root 1.7K Jun 4 05:19 webs_upgrade.log
-rw-r--r-- 1 admin root 388 Jun 5 02:19 wiredclientlist.json
-rw-rw-rw- 1 admin root 943 May 5 2018 wl0_hapd.conf
-rw-rw-rw- 1 admin root 948 May 5 2018 wl1_hapd.conf
-rw-rw-rw- 1 admin root 616 Jun 4 05:19 wlan_update.txt
lrwxrwxrwx 1 admin root 8 May 5 2018 wpa_cli -> /sbin/rc
srwxrwxrwx 1 admin root 0 May 5 2018 wpa_ctrl_1391-1
srwxrwxrwx 1 admin root 0 May 5 2018 wpa_ctrl_1391-2
lrwxrwxrwx 1 admin root 8 May 5 2018 zcip -> /sbin/rc
Same situation here. I’ve reported it via feedback option on the router but not sure if it would be read by asus. This error seems to be happening when instant guard is being enabled. Funny thing is, that there are plenty of free space on the internal disk and memory have got some free chunks either. I thought there are privilege issues of the file as it doesn’t really have write bits set. Changed it and same issue remains. Also, what is funny, after some time, system log will show that it can not fork processes, however, all seems to work for a while but after some time VPN connection would be dropped. If, free memory/ disk is really an issue, while data guard being activated, it’s really a shame and i did not expect such bad testing of the products by asus. My router is a couple of days old and having such issues from the beginning is big disappointment. It’s not that i really need VPN that much but...
L Log flood by dnsmasq ASUSWRT - Official 8
