Download master
Scorpy73
every time I try to install an USB application Download Master (on RT-AC66U) I get this error message:
"The remote server is not responding"
I use the latest firmware 380.63_2.
Is there some problem with the firmware version?
There is something I can do to fix this issue?
Thanks.
I just installed it, although mine is on an ARM device.
The installer contacts asus.com and dlcdnet.asus.com and then needs to connect to ipkg.nslu2-linux.org, dlcdnet-ds.asus.com.edgesuite.net and a whole bunch of other (sub)domains.
Make sure this is not blocked in your LAN.
With new firmware 380.64 the problem is solved. Version 3.1.0.95 of download master has been downloaded.
Now everything is working properly.
Thanks.
