Error while Building.
SomeWhereOverTheRainBow
Part of the Furniture
init-broadcom.o: In function `set_acs_ifnames':
init-broadcom.c:(.text.set_acs_ifnames+0xa0): undefined reference to `wl_list_5g_chans'
init-broadcom.c:(.text.set_acs_ifnames+0xbc): undefined reference to `wl_list_5g_chans'
init-broadcom.c:(.text.set_acs_ifnames+0xdc): undefined reference to `wl_list_5g_chans'
collect2: ld returned 1 exit status
Makefile:687: recipe for target 'rc' failed
make[4]: *** [rc] Error 1
make[4]: Leaving directory '/home/router/asuswrt-merlin.ng-build/release/src/router/rc'
Makefile:2716: recipe for target 'rc' failed
make[3]: *** [rc] Error 2
make[3]: Leaving directory '/home/router/asuswrt-merlin.ng-build/release/src/router'
Makefile:426: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/home/router/asuswrt-merlin.ng-build/release/src-rt-6.x.4708'
Makefile:4044: recipe for target 'bin' failed
make[1]: *** [bin] Error 2
make[1]: Leaving directory '/home/router/asuswrt-merlin.ng-build/release/src-rt-6.x.4708'
Makefile:4186: recipe for target 'rt-ac56u' fai
i am trying to build for my RT-AC56u
The RT-AC56U hasn't been supported since 384.6. You won't be able to compile it.
Not if i am trying off of that base? I mean i am compiling from 384.6.
These errors generally indicate you are using incompatible binary blobs, so I suspect you might not have properly checked out from that tag.
yes I suspected that. so I redid the whole process, i didn't get any further, so I then redid the environment again, this time i download the Last GPL you commited for the 56U and I used the prebuild tool, and committed the changes to the build environment, proceded to build and I got alot further, but the issue this time wasn't an RC issue, but it became an httpd build error after that.
