Escaping bug in helper.sh
Dabombber
The _quote function used in helper.sh escapes the pipe character '|' and ignores the ampersand '&'.
_quote() {
    echo $1 | sed 's/[]\/$*.^|[]/\\&/g'
Examples where this is broken, and an echo bug for good measure:
#!/bin/sh
source /usr/sbin/helper.sh
TMPFILE="output.txt"
echo -e "a\nb\nc\n" > "$TMPFILE"
pc_replace "|b" "123" "$TMPFILE"
echo 'pc_replace "|b" "123" "$TMPFILE"'
cat "$TMPFILE"
pc_replace "b" "&123&" "$TMPFILE"
echo 'pc_replace "b" "&123&" "$TMPFILE"'
cat "$TMPFILE"
pc_replace "b" "-n" "$TMPFILE"
echo 'pc_replace "b" "-n" "$TMPFILE"'
cat "$TMPFILE"
rm "$TMPFILE"
$ sh test.sh
123a
123
123c
123
a
b123b
c
a
c
This could be fixed by changing the _quote function to
_quote() {
    printf "%s\n" "$1" | sed 's/[]\/$*.^&[]/\\&/g'
So there's also a bit of weirdness with the 'a' sed option.
$ echo -e "abc\ndef\n" | sed "/b/a123"
abc
123
def
$ echo -e "abc\ndef\n" | sed "/b/a\123"
abc
123
def
$ echo -e "abc\ndef\n" | sed "/b/a\\123"
abc
123
def
$ echo -e "abc\ndef\n" | sed "/b/a\\\123"
abc
123
def
$ echo -e "abc\ndef\n" | sed "/b/a\\\\123"
abc
123
def
$ echo -e "abc\ndef\n" | sed "/b/a\\\\\123"
abc
\123
def
It seems the fourth and last examples are "right", so pc_insert should be:
pc_insert() {
    PATTERN=$(_quote "$1")
    CONTENT=$(_quote "$2")
    sed -i "/$PATTERN/a\\\$CONTENT" $3
There's no print command in the firmware.
Are you sure you are running your tests using ash and not bash?
# which printf
/usr/bin/printf
# file /usr/bin/printf
/usr/bin/printf: symbolic link to ../../bin/busybox
Gotcha. For some reason I was trying to use print instead of printf.
Urgh, looks like I missed a 'n' after the backslashes, but then that doesn't work either.
$ echo -e "abc\ndef\n" | sed "/b/a\\\n123"
abc
123
def
> 123"
abc
123
def
I guess that was a one line syntax for some non GNU sed, but escaped characters seem to be handled differently in busybox. Where the standard is:
$ echo -e "abc\ndef\n" | sed -e "/b/a\\" -e "123"
abc
123
def
It is possible to use whitespace instead of backslashes, but then you lose any whitespace at the start of the replacement which isn't useful. And the reason backslashes weren't working was the shell doing its own thing before sed
$ echo -e "abc\ndef\n" | sed -e '/b/a\' -e '\\123'
abc
\123
def
$ echo -e "abc\ndef\n" | sed -e "/b/a\\" -e "\\\\123"
abc
\123
def
Some tests with fixed? functions.
#!/bin/sh
_quote() {
pc_replace_a() {
    PATTERN="$(_quote "$1")"
    CONTENT="$(_quote "$2")"
$CONTENT" "$3"
pc_replace_b() {
    sed -i -e "/$PATTERN/a\\" -e "$CONTENT" "$3"
test() {
    pc_replace_a "$1" "$2" "$TMPFILE"
    echo "pc_replace_a($1, $2)"
    cat "$TMPFILE"
    pc_replace_b "$1" "$2" "$TMPFILE"
    echo "pc_replace_b($1, $2)"
    cat "$TMPFILE"
    rm "$TMPFILE"
test "b" "&123&"
test "|b" "123"
test "b" "-n"
test "b" "\\"
test "b" "\$"
$ sh test.sh
pc_replace_a(b, &123&)
a
b
&123&
c
pc_replace_b(b, &123&)
a
b
&123&
c
pc_replace_a(|b, 123)
a
b
c
pc_replace_b(|b, 123)
a
b
c
pc_replace_a(b, -n)
a
b
-n
c
pc_replace_b(b, -n)
a
b
-n
c
pc_replace_a(b, \)
a
b
c
pc_replace_b(b, \)
a
b
c
pc_replace_a(b, $)
a
b
c
pc_replace_b(b, $)
a
b
c
