ASUS DDNS bug?
lumia
Hello
my isp give me dynamic ip who chages every 2-3 days
when this change happens the router seems to have a problem to update asus ddns with the new ip
the same problem exists when i unplug wan cable from modem to the asus router and when i close and reopen manualy internet connection from asus GUI
im preaty sure asus DDNS works perfect because every time i reboot the router from the power button the DDNS works perfect with the new ip.
modem : (bridge mode) to asus WAN1G
Router : 86upro 3004.388.4 (clean install without addons)
LOG : when i unplug 1G wan cable
kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link DOWN.
WAN(0)_Connection: Fail to connect with some issues.
WAN(0)_Connection: WAN(0) link down.
kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link Up at 1000 mbps full duplex
WAN(0)_Connection: WAN(0) link up.
rc_service: wanduck 21559:notify_rc restart_wan_if 0
pppd[21605]: Hangup (SIGHUP)
pppd[21605]: Terminating on signal 15
pppd[21605]: Connect time 2.2 minutes.
pppd[21605]: Sent 240747 bytes, received 227276 bytes.
dnsmasq[21592]: read /etc/hosts - 22 names
dnsmasq[21592]: using nameserver 1.1.1.2#53
dnsmasq[21592]: using nameserver 1.0.0.2#53
pppd[21605]: Connection terminated.
pppd[21605]: Sent PADT
pppd[21605]: Exit.
pppd[23432]: Plugin rp-pppoe.so loaded.
pppd[23432]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.7
pppd[23434]: pppd 2.4.7 started by admin, uid 0
pppd[23434]: PPP session is 24211 (0x5e93)
pppd[23434]: Connected to e0:ac:XX:XX:XX:XX via interface eth0
pppd[23434]: Using interface ppp0
pppd[23434]: Connect: ppp0 <--> eth0
pppd[23434]: PAP authentication succeeded
pppd[23434]: peer from calling number E0:AC:XX:XX:XX:XX authorized
pppd[23434]: local IP address 37.X.X.X
pppd[23434]: remote IP address 62.X.X.X
wan: finish adding multi routes
ddns: WAN(0) IP is empty.(10)
WAN(0)_Connection: WAN was restored.
zcip_client: configured 169.254.189.203
wlceventd: wlceventd_proc_event(831): eth7: Radar detected
cfg_server: cm_updateChanspec call wl_chanspec_changed_action
cfg_server: event: wl_chanspec_changed_action_a101 of eid(0) of cfgs(22781)
rc_service: cfg_server 22781:notify_rc update_nbr
Is there a solution to this problem?
Switch to another DDNS provider and enable host name verification. Asus DDNS does not seem to have this built-in.
I use Asus also and I noticed after the last update, DDNS keeps going to inactive status every few days.
