ExpressVPN Lightway protocol / wireguard
unclebuk
Recently ExpressVPN launched their version of Wireguard called LightWay and it is available on their desktop and mobile device apps AND on their Asus router app. The app works on the AC87U, AC68U & AC56U models only. Has anyone flashed the ExpressVPN router app f/w on one of these routers or any other Asus router models and tested the new LightWay protocol?
I have tried Lightway on an android and macOS laptop and its MUCH faster than OpenVPN and IKEv2. I am tempted to flash my AC88U but expressVPN says it could brick the router. I am no expert but the AC87U (supported model) and AC88U seem very smiliar in design and whats under the hood including the cpu's so I am thinking the f/w may very well work ok on the 88U.
Any thoughts or comments are appreciated.
Regards,
buk
L&LD
Part of the Furniture
The RT-AC87U with the Quantenna chipset is not similar at all to the RT-AC88U.
If you really want to flash it, say goodbye to your RT-AC88U first. :)
unclebuk
Ah, okay. So, the wireless chipsets are on the critical path for f/w flashing?
My thinking was that the wireless NIC (Quentenna) may not have much impact at all compared to that of CPU specs?
But hey, if you say so, since u r a part of the furniture I gotta run with that.
Thanks, much obliged!
L&LD
Nah, don't take my word for it. :)
The firmware isn't an entity onto itself. It is very much tied to the complex workings of the hardware it is created for. I just gave one example of why they aren't similar.
You may be right that it will work with the RT-AC88U. But I wouldn't bet my router on it. :)
