I joined this forum a few days ago to learn more about my router and hopefully to contribute something.
Unfortunately, my first post is about a problem and I need assistance on an issue.
This is my second N66U, the first one I received having a defective lan port out of the box (intermittent connectivity which was not solved by swapping cables - lan ports 2-4 operated perfectly).
My RMA replacement from the reseller is fine with no dead ports but there is one irritating problem. Yesterday, while adjusting the antennae I noticed that one of them seemed a bit loose (it would not stay put at a 45 degree angle). I unscrewed it from the router and gave it a look-over.
I could see that it was not completely firmly coupled and the one side of the connector slipped out from the other part (not really sure which really is the male or female part). Examining it, I could see that nothing was broken and the connection seemed to be a pressure coupling with some small grooves on the one side of the metal connector seemingly designed to "dig" into the plastic of the other.
I pressed the two parts of the coupling together and it is now reasonably firmly seated but I know if I turn it one way or the other a couple of times it will become uncoupled.
How do I handle this? I do NOT want to return the router for another RMA as I simply just need another antenna. I don't believe my reseller has the antennae, so the next choice is ASUS. They sell one antenna for $15 but shipping to Montreal is $15 and $30 seems a little too much for me.
So I can deal with warranty support but I really don't want to have to mail the faulty antenna back to Asus (being deprived of one of my antennae) and end up waiting some 2 weeks.
Any ideas on this and is this type of occurrence very rare? Any input would be most appreciated.
