scMerlin Feedback wanted on potential feature for v2
OMG! What's next? Grafana and Zabbix integration? :p:cool:
You continue to out do yourself @Jack Yaz !
Really enjoy what you've done with this @Jack Yaz ... here's a thought though ... I use the existing text only v1.1.3 on my AiMesh Nodes where amtm comes with firmware and via SSH can install useful utilities such as nsrum / scMerlin / Entware packages / Disk check for small USB where Entware resides.
Not sure how scMerlin v2.0 will go with its webui page which cannot be accessed on AiMesh Nodes ? Hopefully my concerns are unfounded and you will have a ready solution ;).
The nodes are taking over.
:eek:
cli access is unchanged and still available
Hi! current version is scmerlin 2.0.0 on ASUS RT-AC3200 asuswrt-merlin 384.13.10
your mentionned patch is already included in my version.
Still empty "Temperatures" lines on webUI
command line says:
## v2.0.0 on RT-AC3200 ##
Temperatures
CPU:63°C
2.4 GHz: 47°C
5 GHz: 49.5°C
Press enter to continue...
Can you help ?
Really like the new page, any way to get an option on the temperature format to be in Fahrenheit?
command line says:
Temperatures
CPU:63°C
2.4 GHz: 47°C
5 GHz: 49.5°C
Can you help ?
I'll check the source for that model/branch
Temperatures
CPU:63°C
2.4 GHz: 47°C
5 GHz: 49.5°C
May it be caused by the fact that there is NO space after the colon symbol on CPU line
There is no version number at the beginning of your script
Here is the content of /tmp/var/wwwext/user2.asp ( 30339 Nov 13 18:36 /tmp/var/wwwext/user2.asp) :
function update_temperatures(){
$j.ajax({
url: '/ajax_coretmp.asp',
dataType: 'script',
error: function(xhr){
update_temperatures();
success: function(response){
code = "<b>2.4 GHz:</b><span> " + curr_coreTmp_2_raw + "</span>";
if(typeof wl_info.band5g_2_support == 'undefined' || wl_info.band5g_2_support == null){
code += "&nbsp;&nbsp;-&nbsp;&nbsp;<b>5 GHz:</b> <span>" + curr_coreTmp_5_raw + "</span>";
else{
if(wl_info.band5g_2_support){
code += "&nbsp;&nbsp;-&nbsp;&nbsp;<b>5 GHz-1:</b> <span>" + curr_coreTmp_5_raw + "</span>";
code += "&nbsp;&nbsp;-&nbsp;&nbsp;<b>5 GHz-2:</b> <span>" + curr_coreTmp_52_raw + "</span>";
else if (band5g_support){
var CPUTemp = "";
if(typeof curr_cpuTemp === 'undefined' || curr_cpuTemp === null){
CPUTemp = curr_coreTmp_cpu;
else{
CPUTemp = curr_cpuTemp;
if(CPUTemp != ""){
code +="&nbsp;&nbsp;-&nbsp;&nbsp;<b>CPU:</b> <span>" + parseInt(CPUTemp) +"&deg;C</span>";
document.getElementById("temp_td").innerHTML = code;
setTimeout("update_temperatures();", 3000);
